camerondownunder88 Posted June 6, 2007 Report Posted June 6, 2007 Hi, Just out sourcing more info on K motor cyclinder head valve seals. Now we all know the 4K and better valve seals seal a whole world better than K motor seals. So What I am just after is a picture of some 3K old style seals then some newer 4K seals? Or just info on how to install newer style seals into an older head? Cheers Cameron Quote
Felix Posted June 6, 2007 Report Posted June 6, 2007 (edited) With the earlier heads the valves stems have 2 grooves machined in them, one for the spring retainer collets and one for the o-rings which mount in the spring retainer. ie. crap oil consumption unless the guides are good. The later motors (ke30 3k and on) have valve stem seals which clip on to the valve guides. If you want to install the later valve stem seals into an earlier head, you need to replace the valve guides with the later ones. Edited June 6, 2007 by Felix Quote
camerondownunder88 Posted June 6, 2007 Author Report Posted June 6, 2007 So if you can confirm Felix below is the valve stem on the left an old style and on the right a new style? Or is the one on the left a new style just minus the rubber top and spring? As the one on the left is more of a straight shaft with a rounded in part to say it the best section near the top of the stem while the other right one is a straight shaft with a larger diameter top section and no rounded in section. Cheers Cameron Quote
Felix Posted June 6, 2007 Report Posted June 6, 2007 Your pic is not real clear. Looks to me like the later style guides, which have a groove to which the valve stem seal clips on. On the left the valve stem seal has been removed. The valve stem seal is still present on the right. Quote
Taz_Rx Posted June 7, 2007 Report Posted June 7, 2007 Trying to change the seals in my head at the moment, its the old style o-ring type. How do I actually get to them to change them? :P Quote
Robert Posted June 7, 2007 Report Posted June 7, 2007 You need to remove the valve spring, with a valve spring compressor. And then just flip the seal off with a flat screwdiver and push the new seal on. Quote
camerondownunder88 Posted June 7, 2007 Author Report Posted June 7, 2007 Taz just read my PM's...lol remove spring rip off seal. Also Felix I have new type of valve guides in the K big port head but when it gets the head rebuilt I will be removing them and installing new guides as they look a bit worn. Quote
Felix Posted June 7, 2007 Report Posted June 7, 2007 (edited) The o-ring type sit on a groove on the valve stem below the valve collets, inside of the valve spring retainer. Pretty piss poor setup really, they do f@$k all if the guides are worn. If I was to run an early type head I would adapt a set of escort umbrella type valve stem seals. Edited June 7, 2007 by Felix Quote
Taz_Rx Posted June 7, 2007 Report Posted June 7, 2007 ok, I think I've got it sorted now. Just let me do a quick paint drawing to confirm it with you guys......haven't got cam cable! There wasn't any in the head when I got it, thats why I don't know wee they go. Quote
camerondownunder88 Posted June 7, 2007 Author Report Posted June 7, 2007 Si one word...........MSN..lol free to get then u can ask me anything pretty much 24/7..lol As you have my msn address. Cameron Quote
Taz_Rx Posted June 7, 2007 Report Posted June 7, 2007 in some ways MSN would be a very bad idea for me. I waste enough time at work on here a day!! :P Ok, heres my sexy pic.... :D Quote
Felix Posted June 7, 2007 Report Posted June 7, 2007 (edited) Actually thinking about it, the o-ring seals may slip on the top (top groove of stem) of the valve stem after the collets have been installed. Sorry, it has been about 6 years since I last played with a bigport head. The bigport heads I have are unfortunately not here. Edited June 7, 2007 by Felix Quote
camerondownunder88 Posted June 7, 2007 Author Report Posted June 7, 2007 STOP.... Just checked the manual I have for early K motor heads..... And the o-ring seal goes onto the TOP TOP grove in the valve stem. So put it on top of the valve retainer clips that fall out when you remove the spring. Quote
madrolla68 Posted June 7, 2007 Report Posted June 7, 2007 in some ways MSN would be a very bad idea for me. I waste enough time at work on here a day!! :P Ok, heres my sexy pic.... :D No man thats how the holden/chev ones are. You need to put it on the top of the collest like felix said on the TOP groove. Quote
Taz_Rx Posted June 7, 2007 Report Posted June 7, 2007 so like this? I can't under stand why felix was saying the do f@$k all then!! So you don't even really have to take the springs off? or just compress them? I've got them all out now anyway. Quote
