1987 Toyota Corolla FX-GT
Blueprint Blue
20V 4AG-TE (GZE Block, 20V Head)
Microtech LT12
GT28 Turbo
Custom alloy plenum with bellmouthed runners and falcon TB
550cc 13B Injectors
Exh manifold, dump and 3" exhaust
alloy radiator
MR2 5 speed, LSD and driveshafts (aftermarket LSD centre)
Full Recaro interior, genuine front seats, rear (if i use them)
Aftermarket GT Bodykit (not fitted)
17" Mags (not fitted)
Superstrut brakes
Future & Updates
- Complete conversion
- Put car back together
- Fix up paint and polish
- Essentially getting it up and running before future plans
Car in its almost current state, motor has been fitted, only wiring needed to have running
Engine in its former glory with a GT30, approx 185kws @ 18psi
Wanted loom that runs from kick panel to the fuse box. Loom sourced. Thanks Chrisso]
Edited by faulksy
  • 3 months later...
Finally some progress:
- Hacked up engine bay wiring replaced and tidied up
- Replaced GT30 with GT28 turbo and better designed turbo manifold. Bye bye GT30 and lag. But boy it was great when it came on boost though
- Minor oil leak fixed
- New alloy plate welded on plenum runners as didn't fit flush and leaked. Now have one piece of alloy instead of previous design which had mounted each runner individually.
Work still needed to completed have on the road:
- Front mounting an intercooler to replace the barrel. Still haven't decided what intercooler I'll end up using. Depends what fits.
- Installation of a standard radiator to replace the alloy one and fitting super strut brakes
- Relocation of the dry cell battery into the boot, allowing more room for intercooler plumbing
- Dyno tuning new LT12 which replaces the MTX8. LT12 will allow for VVT to be connected up. I'm interested in seeing what difference this may make.
- Bolting back on front panels and bonnet. Replacement of barrel intercooler and alloy radiator has allowed a normal bonnet latch to be connect. Previously had bonnet pins.
Also hoping to fix up the paint if money permits but might just cut it back, polish for the interim and fix up later.
Will try to get some new pics once the car is moved from its current location. The car is wedged between two others making it difficult to get any reasonable pics
