cashie Posted May 15, 2007 Report Posted May 15, 2007 gday i have just recently bought a ke55 coupe and i want to buy some rims for it but i am unsure what size to get i was thinking 16's but i am unsure could some1 plz off me sum help thanks Quote
flat out Posted May 15, 2007 Report Posted May 15, 2007 (edited) my opinions would be, konig rewinds 14x6 and 15x7 off the top of my head $250 round about performance challanger 14x6 14x7 15x6 15x7 15x8 15x10 but i highly recommend staying under 15x8 i know 14x7 are $200 15x7 $240, and 15x8 $260 performance superlite all of the above , roughly the same as challangers performance spitfire 14x7 unsure but no more than $200 i would think otomoto te37 style coppys 16x8 $280 these are suited to rwd cars and will fill your guards, most 16's you get will be front wheel drive offset and may require bolt on spacers which are illegal all prices are per wheel Edited May 15, 2007 by flat out Quote
cashie Posted May 15, 2007 Author Report Posted May 15, 2007 thanks 4 the help m8 now all i gotta do is save the cash 4 them Quote
flat out Posted May 15, 2007 Report Posted May 15, 2007 oh ill add prices too cause I'm bored as! Quote
HEKTIC Posted May 15, 2007 Report Posted May 15, 2007 my vote would be 15x8 -4 offset performance superlites with charcoal centers and polished lip they are about $1000? for a set of 4 without tyres! but would look horn on your coupe! Quote
Ben Dover Posted May 15, 2007 Report Posted May 15, 2007 yea go 15s man My god can't it just be simple, like a set of cressida 15'x6' runing the cressida nuts and either a 195/60r15 which fills my guards quite well , or 195/50r15 if you want some thing a bit sportier. Wheels fit with the right offset and have toyota on the centre cap. Good Luck Ben Dover Quote
Jordan Posted May 16, 2007 Report Posted May 16, 2007 I've got 15x8 Challengers. they have a -9 offset (and are also avalaiable in 15x10, ok that's a bit out there but hey.) the 15x8's "will" fit under your guards, with 50 profile rubber and tyres no wider than 205. I've got them on my TA22 (and they look hot) with 195/50R15's and the back is fine but guard rubbing is a problem, as the car is quite low. Cheers Jordan Quote
cashie Posted May 19, 2007 Author Report Posted May 19, 2007 I've got 15x8 Challengers. they have a -9 offset (and are also avalaiable in 15x10, ok that's a bit out there but hey.) the 15x8's "will" fit under your guards, with 50 profile rubber and tyres no wider than 205. I've got them on my TA22 (and they look hot) with 195/50R15's and the back is fine but guard rubbing is a problem, as the car is quite low. Cheers Jordan r there any websites i can check these rims out at thanks Quote
