-RoBeRtO- Posted May 14, 2007 Report Posted May 14, 2007 (edited) hey all, my speedo in my ke70 just flickers up and down when i drive, ive taken out the speedo unit and reattached the plug that goes in the back but it still just flickers up and down. does anyone have any idea how to fix this? cheers, chris Edited May 14, 2007 by -RoBeRtO- Quote
7shades Posted May 15, 2007 Report Posted May 15, 2007 Check the speedo drive cog on the gearbox end of the speedo cable. Its probably missing some teeth. (They're only nylon) You can still get them new from Toyota but you'll have to take your old one with you so they can decipher the numbers on it and give you the right one. Quote
coln72 Posted May 15, 2007 Report Posted May 15, 2007 or pull out the cable from the back of the speedo and spray some wd40 or put a dob of grease on the end of the cable. Quote
Des Posted May 15, 2007 Report Posted May 15, 2007 If its still broken after coln72's suggestion i have a working speedo/dash here you can have for nothing, If you want it you can pick it up from Hamilton on the northside of Brisbane this coming Monday. Des :yes: Quote
-RoBeRtO- Posted May 16, 2007 Author Report Posted May 16, 2007 hey guys thanks for your suggestions, coln72 it works good now it just needed a good spray and some grease.. ae70 id love to take your speedo/dash for a spare but you live pretty far from were i am. Quote
old corolla bloke Posted May 17, 2007 Report Posted May 17, 2007 hey all, my speedo in my ke70 just flickers up and down when i drive, ive taken out the speedo unit and reattached the plug that goes in the back but it still just flickers up and down. does anyone have any idea how to fix this? cheers, chris i reckon Id be going to a wrecker and getting a speedo cable pretty soon old corolla bloke Quote
coln72 Posted May 17, 2007 Report Posted May 17, 2007 Nah, last for ages after a bit of a lube :cool: Quote
old corolla bloke Posted May 18, 2007 Report Posted May 18, 2007 Nah, last for ages after a bit of a lube :cool: in my experience, all be it limited. the common cause for this type of problem is that the speedo cable is broken about 50 to 75mm out of the gear box at the bend in the cable. this can be checked simply by undoing the cable from the drive and pulling the inner cable. the flicking is caused by the cable ends rubbing together and transfering partial drive to the speed head. should this not be the case and the cable is not damaged its easy to push it back making sure it has engaged the speedo head drive. old corolla bloke Quote
-RoBeRtO- Posted May 20, 2007 Author Report Posted May 20, 2007 old corolla bloke thanks for the information, its much appreciated. ill bring it to work asap and fix it. i put lube in it but it still flickers just a little bit. Quote
