Are the stud patterns the same on a KE20 motor as on a 4K KE55 ? Would you think an aftermarket KE20 ehaust header would then fit a KE55 ?
I'd really appreciate any advice here
Thanks Pete
  anastasios said:
i have a set of tuned extractors for a ke20 with 02 sensor aswell, i will need to get them into my 55 so i will let you know how it goes
Thanks anastasios, good luck, notice coln72's response above, not 100% sure what that means
Let's know how you go
Thanks Pete
  coln72 said:
Yes it will bolt to the motor :)
No it wont fit into your shell ;)
Thanks coln, what do you mean by "shell"...............do you mean the engine bay? where is it going to foul something?
Is it just a matter of bending the pipe/s ?
Thanks for your help, ........Pete
  anastasios said:
it hits the fire wall, so I'm going to see how bad it actually is as i might be able to fix it with a hammer
Thanks Anastasios, let's know how you go with the hammer!
Coln72, is Anastasios' experience what you're talking about...........hitting the firewall?
Can't the pipes be heated and bent enough effectively, or the firewall dented?
They would probably fit, though you would need to cut the pipe off at the collector and remake a new one.
The pacemaker extractors in my ke15 were originally in a ke30 before I got them. I had to do the above.
thanks Felix
