Junior Speedway car. As I'm a total newbie to these cars I'll ask the dumb ? Cars fueling up at idle. Choofing black smoke out the exhaust. Also it's fueling up at when she's cornering (foot off) . Where do I start? Std carby type is all we're allowed to run. Jetting is free. Don't have time for a dyno run this week so I need to sort this before the weekend as she's (13 y/o) is racing again (keen).trikes
Is that it? What no one knows where to start with this carby? Hummm.....trikes out
Swap no. 2 & 3 plug leads. Hold foot flat and hit the starter. Backfires will clear out some of the shit. And by the way, remove aircleaner first :kiwi:
with out seeing the car running its a bit hard to guess what it wrong BUT here is a stab
i think your float level is a bit high
or if you have an electric pump the fuel pressure from the pump is excessive try a regulator between the pump and the carby holley do a good,cheap simple one
i hope this helps
old corolla bloke
