spraycanmansam Posted March 20, 2007 Author Report Posted March 20, 2007 why is that a problem? any reason you don't like to rev? i'm sure you'd find the 20v has sufficient grunt in an ae82, if not, i've heard 626 turbos hunt gutters pretty well. Its not a problem, i just feel like something different for a change. All i see around here are turbo AE82 or AE92s. Id rather hear the whine of a charger than ssssss...PSSS-CHHEESSHH!! for a change. you are aware that trying to be "different" in the worlds best selling car is a bit of an oxymoron? Its not so much about the car.. The engine is more my focus. Once its finished there are heaps of potential cars to transplant it into. The AE82 was the cheapest lightest car for me. I picked it up in awesome condition, 1 lady driver. They needed it gone coz they were moving.. $100 and a new windscreen! :yes: Its not i don't like to rev either... its i don't want to have to.. :D Does anyone have any helpful suggestions!? Cheers Quote
spraycanmansam Posted March 20, 2007 Author Report Posted March 20, 2007 i've heard 626 turbos hunt gutters pretty well. um, whatever that means? Quote
doityourself Posted March 20, 2007 Report Posted March 20, 2007 Mate there are only a few blower that will be able to keep up with a 20v and none of them are toyota built. If you want to be serious about it, your are going to need to get yourself a Vortech Centrifugal blower. Something like a Vortech V5 should do the job well. Quote
spraycanmansam Posted March 20, 2007 Author Report Posted March 20, 2007 Mate there are only a few blower that will be able to keep up with a 20v and none of them are toyota built.If you want to be serious about it, your are going to need to get yourself a Vortech Centrifugal blower. Something like a Vortech V5 should do the job well. Your think the same as me; a centrifugal charger would be perfect.. nice smooth boost curve, etc. but the PRICE!! damn they're expensive! Still.. would be nice and quiet... :D Can someone explain to me why they can't keep up? I think i understand where ur coming from, i jus wan2 make sure. Is it to do with, RPM, psi, cfm? Quote
doityourself Posted March 20, 2007 Report Posted March 20, 2007 A roots blower is ok but it can't force much air as there are only two 4 lobes (2 pairs) inside. The roots blower design started way back when they were originally used on diesel motors. CON - they are not designed to spin fast, therefore are a more inefficent way to supercharge PRO - cheap to maufacture The centrifugal blower on the other hand is a turbo compressor housing connected to a gearbox (single speed - steps up revolutions) and to a pulley. This type of blower can really spin hard, I have heard as much a 80,000rpm CON - expensive to manufacture PRO - extremely effective. Quote
spraycanmansam Posted March 20, 2007 Author Report Posted March 20, 2007 Yeah thats why i would LIKE a centrifugal as the boost would increase smoothly over the rev range. 1 thing I have found interesting is that when reading debates over 'which flows more? 20v or 16v?' most people agree that the bigport flows more. Now when i want to add a supercharger from an engine equipped with a bigport head, they say it wont be able to flow enough air for the supposedly inferior flowing 20v head...? See where I'm comin from? :D Quote
Raven Posted March 20, 2007 Report Posted March 20, 2007 um, whatever that means? He means torque steer city. Quote
anastasios Posted March 21, 2007 Report Posted March 21, 2007 the flow difference isnt that huge mate to allow a smaller charger to work, if you want something different its going to come at a price, its like me saying i want to irs my ke55 for something different Quote
spraycanmansam Posted March 21, 2007 Author Report Posted March 21, 2007 the flow difference isnt that huge mate to allow a smaller charger to work, if you want something different its going to come at a price, its like me saying i want to irs my ke55 for something different He he I'm pretty sure I've seen that done before! a yellow one.. 4AGZE, etc. Actually supercharging its going to be cheaper for me :D Quote
anastasios Posted March 21, 2007 Report Posted March 21, 2007 yea it might be cheaper but its a waste of a motor and wont be working to the full potential, you might aswell leave it n/a Quote
Guest Sbox Posted March 22, 2007 Report Posted March 22, 2007 (edited) Deleted Edited May 24, 2008 by Sbox Quote
andro0o Posted March 22, 2007 Report Posted March 22, 2007 ive got a cheap turbo you can buy... its off a wrx... comes with intercooler and all the rest of it.... pm me if ur interested... Quote
towe001 Posted March 23, 2007 Report Posted March 23, 2007 Or you could just re-work the cams and cam timing for better bottomend. Re-do the induction side be adding something like a butterfly system to switch between short (high rpm)intake runners and long (low rpm)intake runners. The 20v uses something like the Honda VTEC system, right? Then how about using the switch over point on the intake cam to also switch the charger on and off. Quote
doityourself Posted March 23, 2007 Report Posted March 23, 2007 (edited) My brother seems to think that the SC14 should handle the job ok. He has had experience with a supercharged 18RG on LPG. Edited March 23, 2007 by doityourself Quote
spraycanmansam Posted March 23, 2007 Author Report Posted March 23, 2007 Or you could just re-work the cams and cam timing for better bottomend. Re-do the induction side be adding something like a butterfly system to switch between short (high rpm)intake runners and long (low rpm)intake runners.The 20v uses something like the Honda VTEC system, right? Then how about using the switch over point on the intake cam to also switch the charger on and off. Yes my early 20v uses a similar thing to VTEC, switching the camshaft duration or overlap(?) i forget the rpm.. Id like to look into the adjustable runner idea... thanks And yea i might see how much i can pick up a SC14.. Quote
