Results are extremely provisional, apparently there are a select few that have them for the moment. They are being re-checked. This is only a 2nd hand rumour, but enough to publish!!!
  • Replies 111
In other results:
Fook: 10th O/R 2nd in Class
Mumblezz:16th O/R 5th in Class
Datgirl just behind (damn that wrong direction!) 17th O/R 2nd in class...
Good result had by all!
How is it that both me and Datgirl are 2nd in class? Weren't we in the same class? Or did they nudge me into C class because my car was too long (it was right on the limit of B/C class)?
10th O/R, that's pretty alright considering I recon I had a pretty crappy day...
Thanks for the results!
That's funny cos one of the scrutineers asked Rob about whether to put mumblezz sprinter into class B or C because it was right on the border of both. I don't know what they ended up doing for Paul, but I think we said to him to ask Keith what was usually done. What class is your car normally in Fook/mumblezz??
Redwarf is definitely always class B, so it sounds like Fook you would have been in class C? If you're right on the border, it would be to your advantage to be in class C.
Re: pretty crappy day - I think everyone except Rob had a bad one. Ken Graham came second allegedly and he hit posts. Sounds like Rob was the only one not to hit posts or manage a WD. Usually the top 10 have a flawless day, so that gives you a bit of an indication. Fook, I would have been stoked to make the top 10, you get QMS points for that!! Congrats!
ps. I am pretty keen on this dirt motorkhana on August 29th I keep hearing about but have absolutely no idea how to get supp regs or find out even where to start finding out that info. Who has supp regs?
Edited by datgirl
Mel: I had a clean sheet day too, no WD's or posts. But then I did do quite a few 3-point turns because there were a few turns I couldn't make, and I definately wasn't the quickest around any of the tests.
I'm usually in class B, but that's just cause we've always gone by the stock wheelbase of the car. Seems that with all the suspension modifications my wheelbase is now longer than standard...
Warning: I'm going to be controversial here!!
Rob was ROBBED (pun intended)
The change to the results was about a WD that was overturned and rightly so. However, there are more than 3 witnesses that saw the same person WD another test and the officials did not record it. Having an incorrect WD overturned knowing they WD'd another test is just plain bad sportmanship.
At least we know that Rob was the real winner because bad sports don't count.
Well said!
even if points didn't count, i still think Rob would of come first, for style, precision & a dam good crowd entertainer !
Mel: I agree. People were ringing up and complaining that they didn't remeber hitting any flags etc, and I recon there'd have to be at least one person who either didn't realise they hit a flag, or just wanted more championship points...
But oh well...
