LittleRedSpirit Posted March 23, 2008 Report Posted March 23, 2008 Ok..... So which camber plates work best in a KE70 without buggering up castor? Does running AE86 struts contribute to this problem? If not, which camber tops are best suited? Thanks Chris Struts don't change anything, they just bolt in to the strut top mount. Best to measure the strut tops you plan on using and see how closely they compare to your standard units. The mounting bolt pattern is the same in adm ae71 but the caster position is different to ae86. There is no easy answer, just measurements to be taken. I have tein cambertops which are very close to ae71 pattern. Quote
DjB Posted March 23, 2008 Report Posted March 23, 2008 Just so its 100% clear for me, The Tein items you have are AE86 items? Chris Quote
LittleRedSpirit Posted March 23, 2008 Report Posted March 23, 2008 Just so its 100% clear for me, The Tein items you have are AE86 items? Chris Yes. Caster added Teins I think, but they weren't bought new so who really knows. They came off some secondhand coilovers someone got over from Japan. Quote
towe001 Posted March 24, 2008 Report Posted March 24, 2008 Keeping track of this, its interesting stuff Quote
h1_roll4 Posted September 2, 2008 Report Posted September 2, 2008 i think i read this somewhere so just checking. are ke70 panno struts the same as adm ae86? Quote
beerhead Posted September 2, 2008 Report Posted September 2, 2008 From what I've heard they're in the Japanese import vans. I've seen both girlock and the AE86 gear in them, but I didn't actually check the compliance plates to confirm the rumour. Quote
adam-__- Posted September 2, 2008 Report Posted September 2, 2008 Read somewhere that only the AE71 pannos had the AE86 struts. :P There's a AE71 panno at my local wrecker, I'll check them out to see if they are the same. Hope they haven't crushed it yet though. Quote
LittleRedSpirit Posted September 2, 2008 Report Posted September 2, 2008 Read somewhere that only the AE71 pannos had the AE86 struts. :P There's a AE71 panno at my local wrecker, I'll check them out to see if they are the same. Hope they haven't crushed it yet though. Yep, ae71 has same struts as ae86, but ke70 vans do not. Quote
crazyrob Posted October 22, 2008 Report Posted October 22, 2008 Anyway, to keep things on topic, it seems to be the general consenus that: 1. AE86 front coilovers will bolt into a KE70/AE71 straight away 2. AE86 will not bolt directly into a KE70/AE71 as the KE70/AE71 uses a single bolt shock mount - HOWEVER, by welding in some reinforcing plate, drilling three mounting holes and a big central hole, it is possible to mount the AE86 coilovers. with this if i got ae86 struts i would have to drill all this..? it would just go right in? i have a early ke70 and what our struts could i put in? Quote
adam-__- Posted October 23, 2008 Report Posted October 23, 2008 (edited) with this if i got ae86 struts i would have to drill all this..? it would just go right in? i have a early ke70 and what our struts could i put in? I've got AE86 struts in my car at the moment and all that's needed to fit them into a KE70 (1983 if it matters) is installing AE86 steering arm's as well. You'll be able to fit them with their strut tops, but the castor will be way out, just install the standard tops on the struts. Edit: I just realised that number 2 in what you've quoted is for the rear and yeah, you'll need to reinforce the area where the shock is normally mounted because when you go coilover system, the car's weight is placed where it isn't designed to be. Edited October 23, 2008 by adam-__- Quote
crazyrob Posted October 24, 2008 Report Posted October 24, 2008 thanks adam.. there only going for like $250 and but i don't think ill get coilovers.. Quote
sleepy92 Posted March 31, 2009 Report Posted March 31, 2009 (edited) delete pls Edited March 31, 2009 by sleepy92 Quote
LittleRedSpirit Posted March 31, 2009 Report Posted March 31, 2009 digging up an old thread... just wondering what ae86/ae71/t18/ra40/ra60 front struts are compatible, or close to compatible with ke3x/ke55 front struts? i currently have in my posession a set of ae71 front struts and am wondering whether this is a useful item for my ke35 (very interested to hear about ae71/ae86 strut compatibility because of a set of coilovers with 4 spot calipers i may be able to get hold of) If you want upgrades for ke35, you're in the wrong place. This thread is about similarities between xE7x cars. Try using the search function including google, reading peoples project threads, or if that fails start a new thread in the appropriate area and ask specific questions. Its not really sporting to hijack a thread with this much info on another chassis, with your own different info. Cheers. Quote
-ollie- Posted June 30, 2009 Report Posted June 30, 2009 Does anybody know if AE86 seat rails bolt into the ae71/ ke70? Quote
-ollie- Posted July 9, 2009 Report Posted July 9, 2009 Well, i bought an ADM ae86 driver seat, and it fits, however it was a bit of work to try to bolt it in especially on the front right side so i don't think the mounts are exactly the same, but close enought that if force it, the holes will line up. Also, the plastic cover on the bottom right hand side that covers all the recliner gear rubs up hard against the side of the car i.e. the ae86 seat is about half an inch too wide at the back. I think if i take the cover off it will be alright.... hopefully! Cheers Quote
