HEKTIC Posted January 11, 2008 Report Posted January 11, 2008 you going to try and get 50-50 weight balance? or is that close enough for you Quote
robj Posted January 11, 2008 Author Report Posted January 11, 2008 Gunna bring her for a play in the motorkhana on sunday!? Check the tassie section for details. :fuzz: Nah, unfortunately got something else on this weekend. Quote
robj Posted January 11, 2008 Author Report Posted January 11, 2008 you going to try and get 50-50 weight balance? or is that close enough for you I don't know if I'll do anymore about weight distribution. So far, without even having adjusted basic things like damper ratings, it is handling well for me, so I doubt it. Feeling more confident taking the car to its' limit than Iwas a few months ago. I don't know if that's a good thing, I'm having to exercise self-control, and save it for the track. :fuzz: More keen in getting a better steering feel. Now THAT could be a job in itself.... :bash: Quote
HEKTIC Posted January 11, 2008 Report Posted January 11, 2008 ahhh interesting! rack and pinion? i'd be very interested to see how that goes, contemplated doing it with my ke35 just always thought it'd be tooo hard! Quote
Jono Posted January 12, 2008 Report Posted January 12, 2008 my ke20 went from 760kg to 860kg with the 4age/t50 setup. i think the 15" saab chasers would add a bit, motor, gearbox, seats, ke55 diff and front brakes a little heavier, surge tank and pumps, larger exhaust, larger radiator, brake booster. it all adds up. i've since removed the back seat as its engineered as a two seater. but also added turbo manifold, turbo, intercooler etc. keen to remove the sound deadening and the interior trim and carpet and get some light weight 13"/14" wheels and see what she weighs. Quote
robj Posted January 12, 2008 Author Report Posted January 12, 2008 my ke20 went from 760kg to 860kg with the 4age/t50 setup. i think the 15" saab chasers would add a bit, motor, gearbox, seats, ke55 diff and front brakes a little heavier, surge tank and pumps, larger exhaust, larger radiator, brake booster. it all adds up. i've since removed the back seat as its engineered as a two seater. but also added turbo manifold, turbo, intercooler etc. keen to remove the sound deadening and the interior trim and carpet and get some light weight 13"/14" wheels and see what she weighs. Well, you're 100kg better than mine! I guess the cage, W series 3s will soon add up the weight. I don't have a rear seat in mine anymore either. weight on cars is like money, you don't realise how a little bit here, a little bit there soon adds up to heaps. And HEKTIC, yeah, possibly r and pinion. It is easier in a KE30-55 though, they have shorter LCA, and tierods similar in length to many racks. Quote
robj Posted July 24, 2008 Author Report Posted July 24, 2008 (edited) The car (ke25) is going great, it now has rack and pinion in it. But has a bit (not too bad) bump steer. I was hoping to get rid of all bumpsteer. Last night I played around with different tierod lengths/rack rod lengths, and it is vertually make bump steer completely disappear! (5mm out over 4 metres- can't measure that at the wheel!!) When I fix this small problem up, I'll give a report on it. It is a lot nicer to drive, very tight and good feel. Used mainly KE70 stuff, rack, LCA , column etc. Still need to mount the column to the firewall properly though. Loving it. robj Edit: The vital statistics: I cut the rack bar by 57/58mm. But that was too much. Extending the bar by 11mm on each side (22mm total) so only 35mm shortened of the bar was ideal. LCA inner pivot points are about 6mm BELOW the end of the rack ends, and 287ish mm from the centre line. That is what worked for my KE25. Toe is is quite noticeable in droop, but now virtually non exsistent in bump. Using 40mm RCA blocks at the bottom of the xt130 struts. Edited July 24, 2008 by robj Quote
Doogs Posted July 24, 2008 Report Posted July 24, 2008 Rack and Pinion in a KE25, I like it ! :bash: Could you put up some pics please ? Quote
robj Posted December 18, 2008 Author Report Posted December 18, 2008 The car is going really well now. I've done some 10 000 km, using it nearly every day. That includes a few track days. The Rack and Pinion has a full length rack in it, and works well. Been playing with the computer, and getting down to nearly 8l/100km, but usually around 9l /100km. Track days about 30 l/100km!! Quote
Raven Posted December 18, 2008 Report Posted December 18, 2008 Hey champ. More information with this R&P setup would begreatly appreciated as I've been looking into doing this to my KE25 that I'm rebuilding. Cheers Raven Quote
godlovesugly Posted December 18, 2008 Report Posted December 18, 2008 (edited) Hey champ. More information with this R&P setup would begreatly appreciated as I've been looking into doing this to my KE25 that I'm rebuilding. Cheers Raven also very interested in the R&P mod. ive read that using KP61 starlet R&P is an easy way to do it, but if i had access to a KP61 i would be modifying that instead. EDIT: i just went through and read the whole thing and this car is awesome, and you look like my dad. thats all. Edited December 18, 2008 by godlovesugly Quote
Super Jamie Posted December 18, 2008 Report Posted December 18, 2008 what an amazing car, words cannot express the amount of drool literally pouring from my mouth i can't believe it's actually road registered too, it must be so much fun! :) Quote
Rolliac Posted December 21, 2008 Report Posted December 21, 2008 Does the W-58 fit straight to the engine? What bell housing is used? Quote
Bean5 Posted December 28, 2008 Report Posted December 28, 2008 Hey mate, first of awesome car. Just wandering where you got the flares from, as I'm also doing a KE25 build. Cheers Nick Quote
