Guest Sbox Posted February 12, 2007 Report Posted February 12, 2007 (edited) Deleted Edited May 24, 2008 by Sbox Quote
Jono Posted February 12, 2007 Report Posted February 12, 2007 my mate is using a celica steel case with his gze turbo conversion, he didn't even chance his t50 behind it. Quote
wagon Posted February 12, 2007 Report Posted February 12, 2007 (edited) my t50 last about 2 years behind my 200rwkw 4agte and i raced at calder aswell i blew it by down shifting to quick, it was break the box or hit the truck. Edited February 12, 2007 by wagon Quote
Des Posted February 12, 2007 Report Posted February 12, 2007 The W58 comes from JZA80 2JZGE supra's and a few others. I'm using a T-50 behind my 4AGZE and it should be fine if i respect it. If you drive around clutch kicking on every corner it wont last long. http://www.brisbanemotorimports.com.au/transmissions.htm Quote
Guest Sbox Posted February 13, 2007 Report Posted February 13, 2007 (edited) Deleted Edited May 24, 2008 by Sbox Quote
Des Posted February 13, 2007 Report Posted February 13, 2007 http://www.geocities.com/MotorCity/Pit/997.../Gearboxes.html Quote
Retrospekt Posted February 17, 2007 Report Posted February 17, 2007 JC807 said: my mate is using a celica steel case with his gze turbo conversion, he didn't even chance his t50 behind it. sorry for the silly question, but the steel case celica is box, is it a ta22 celica box? if so arent they the same? Quote
Jono Posted February 17, 2007 Report Posted February 17, 2007 i'm pretty sure the steel case celica box my mate has is the W50 Quote
Des Posted February 17, 2007 Report Posted February 17, 2007 Ta22 had a T50 as its a T series engine ? W50 are from RA40's i believe. Quote
FatTony Posted February 18, 2007 Report Posted February 18, 2007 (edited) AE70 said: Ta22 had a T50 as its a T series engine ? W50 are from RA40's i believe. W50 are behind celicas as early as ra23, they come on the 18r motors, 2T powered ta22 and ta23 celicas used a 20 spline t50 Edited February 18, 2007 by FatTony Quote
