doityourself Posted February 2, 2007 Report Posted February 2, 2007 (edited) Hi all, I am looking into lowering the Green Pea KE30, and do a brake upgrade at the same time. I tried a search but found no luck. I was hoping someone can shed some light on the situation for me. I am hoping to lower the car 2.5 to 3 inches, with a significant rise in spring rate. I intend to use the car for drift / circuit / daily, and I am well aware of the legallities of going so low but if you've seen my wheels you'll know I blatently disregard the law. Thanks in advance Dale Jeffree Edited February 2, 2007 by doityourself Quote
FatTony Posted February 2, 2007 Report Posted February 2, 2007 I think you will find that the steering knuckle on the ke wont bolt into the ta22 strut, so that shall have to be changed with the whole lower control arm, i also think that the upper spring seat does not bolt into the ke strut top without some grinding and drilling, so you can either adjust the car to make it fit, or reweld the ke lower spring seat onto the ta22 strut and run a ke spring and upper spring seat. Quote
doityourself Posted February 2, 2007 Author Report Posted February 2, 2007 (edited) I haven't got any springs handy but are they KE30 and TA22 the same diameter? Edited February 2, 2007 by doityourself Quote
doityourself Posted February 3, 2007 Author Report Posted February 3, 2007 Cheers for that Redwarf. Looks like I'll have to go to Toyoland on monday and start measuring and playing aound Quote
Raven Posted February 3, 2007 Report Posted February 3, 2007 I know KE30 and RA40 are the same diameter, cos my KE30 is running RA40 springs :) Quote
Raven Posted February 3, 2007 Report Posted February 3, 2007 And regarding struts, you put the KE30 top on the TA22 strut. :) Quote
doityourself Posted February 3, 2007 Author Report Posted February 3, 2007 Thanks I've been waiting for an anwer like that. So its TA22, LCA's, Steering arms, springs, and struts. From KE30 its, strut tops. Quote
FatTony Posted February 3, 2007 Report Posted February 3, 2007 Thanks I've been waiting for an anwer like that. So its TA22, LCA's, Steering arms, springs, and struts. From KE30 its, strut tops. I'm sure thats what i said ealier, but i don't think the ke30 spring sits in the ta22 lower seat properly hence you need to weld the ke30 spring seat on the ta22 strut, but i could be wrong. Quote
anastasios Posted February 3, 2007 Report Posted February 3, 2007 you don't need the lca arms all u need is ra40 steering arm, you can use ta22 springs with the ke30 strut tops Quote
doityourself Posted February 4, 2007 Author Report Posted February 4, 2007 Again thanks you all very much, you have all been helpful. Quote
