Hey guys, tried searching but couldn't find specific info.
I damaged my timing gear whilst removing it from my 4agze crank.
Will a 4ac crank timing gear fit on a 4agze? I have access to one but don't want to go out of my way if it wont fit.
If not where would you find a 4agze crank timing gear? Is it the same as the 4age?
Any help would be great. Thanks.
Hey, A mate and i have a few spare GE's in pieces, They should be the same, Count how many teeth it has and i will let you know and i will get it down to you asap.
Trev
Edited by Trev
It has 18 teeth i think from memory. I'm not at home so i can't check.
I need to know if the 4ac gear is the same before i rip a perfectly good engine apart.
Thanks anyway Trev but if the gear is the same as a 4age i've got a mate who's got one.
If your 4age gear has 18 teeth could you let me know. Thanks.
