  madrolla68 said:
Guys let me know what your thoughts are for a new exhaust on my turbo KE10 running the 5K at the moment.
2.5inch from turbo is all you will need, single mufler, not a cannon (this is up to you but it just wouln't be right foer a ke10, loud too)
My brother had an Exa turbo that was 1.5 litres, he used a 2.25 press bent exhaust with a lukey turbo muffler. It flow really well and didn't have that farting in a tin can like cannons give.
On my exa i ran a 2.5" dump pipe off the turbo (Turbo was a 2.3L diesel turbo and the dump pipe stopped under the start of the floor pan) which met up with 3" exhaust with a straight thru lukey turbo box, No mozzies in a milo tin and it flowed very good.
Mines just 2.5 off the turbo till under the passengers feet, then goes into a 2 inch system I bought off here with a very quiet muffler. sounds like a completely stock car when its just sitting there idling.
don't think its going to make any biggy what size you really use, just keep it above 2".
noticed you have a t25 listed in your sig matt! what happened to the saab turbo??
They are essentially the same,it uses a different style of wastegate delivery to the normal bolt on flange type. Just breatha a little easier when the wastegate is activated.
Ok it goes in tomorrow for a press bent 2 1/4' from dump pipe back which is 3".
So hope it goes well afterwards.
Ok so its all done ,but 2 1/2" and man does it make some grunt now.
hey guys i have a 5k motor thats had quite alot of work, eg 4age pistons quad throttles cam etc i was wondering if its necessary to run aftermarket extractors, if so where would i find them for a k series
what do you just have a standard header set-up. Yeah, extractors will make a difference.
Think of it this way: Would it be easier to take a shit if you had a bigger more free flowing arse hole!!!?? :)
same with intake, can "eat" more air if you have a bigger mouth!! but then a big mouth isn't all that much better if you don't have an appropiately sized throat (manifold, ports and valves).
BTW matty, when we gunna see a vid so we can hear what she sounds like now?? :)
I will get some video on my phone tomorrow man, i don't have a video camera yet.
I am in the process of fitting 7Mg injectors from a supra cause mine are out of puff at 12 PSI now with new exhaust.
  Taz_Rx said:
cool, sounds like things are doing pretty well then. :)
is 12 the highest you've run yet?
even with the cam the torques awesome hey?
No ive had it at 20 PSI but only down low as it leans out real bad.
Yeah the torque is killer man.
Edited by madrolla68
