Hello All,
So I got myself a 4-speed manual KE70 Corolla for $500 and started "sprucing" it up a bit. The car was in Okay condition when i purchased it however it needed some panel beating and fresh paint. also the rims made it look a tad better. Ive got most of the interior and exterior done, however the stock 1.3L engine doesn't quite have enough go for my liking :jamie: Does anyone have any suggestions for a higher power engine that is relatively easy/cheap to come across that works well in a KE70? Any suggestions welcome.
here is a picture of the car so far...
hi welcome to the rolla club.
All the info you need is at your finger tips.
do you a budget?
where are you?
how much work are you willing to put in?
4age would be my bet.
chris
yeah. 4age if you have some cash to spend, 7k still needs a fair amount of cash but is simpler. Anything else becomes really costly and becomes mor difficult. And i like what you have done to the ke70. gl with it.
thanks for the replies.
as for budget...well, basically saving as much money as i can then ill see what i can come up with.
live in Wagga Wagga, NSW
and, prepared to put alot of effort in.
again, thanks for the relpies :jamie:
4AGE and you wont look back, Parts are a little bit hard to find but once you have them it gets easier.
I have to say that a 5k is the easiest conversion if you want a little more power for a small expense, Chris would probably agree with this (I'm getting a 5k off him for my ke70). I'm going for the 4AGE in my Ke55 with turbo, but it is definately going to cost quite abit more. Research, research and well mate research. I have got off to a bad start and wasted some money, but it's a learning curve. I think by the time my 4AGE is into the 55 I'll be about $4000 worse off, compare that to around a grand for a pokey 5k.
Cheers
Sbox
Cheers
Sbox
but the 4agte will go crap loads harder obviously, twin cam ftw!!
I'm going a ca18 in my 55, but a 4age would be better for a 70, and it keeps it in the family
ae7-'s have a 4a-c, so you can use one of there crossmembers to bolt the engine in, makes things easier
Seems like the 4AGE is the way to go. gonna go check the forum for people who have done this conversion on their car.
Again, thanks all for the comments, very helpful. :jamie:
been checking the forum abit about a 4AGE into a KE70 and started making a list of what i will need to get. dunno how i am going with it (brain hurts) but this is what ive come up with so far:
AE-86 x member and mounts?
T-50 gearbox?
new diff?
new hydraulic clutch?
i know that there is alot of other things that i am missing but if this list is kinda right, i would like to know:)
Super guys.
The man now has starting points to go and research.
Also look in the rides section. Have a look at Teddy, Medicine man and Jason's cars for a start, then keep working through.
Everything you need is in here somewhere.
Set yourself up in the members rides section, and if you have any further questions, stick them in there.
I'm actually quite suprised this thread lasted as long as it did.....
:jamie:
