have a ke55
replaced the battery and altenator and starter motor
but when the terminals are connected and u leave it there it drains the car of its power to start
how can i do a backyarder and fix this sort of thing
get a multimeter and set it to amps. take out a fuse on a circuit and replace with the multimeter leads to see if its drawing any current (make sure your multimeter has short cct protection).
Go to your fuse box adn remove say the heater fuse then the radio fuse as this will save you putting tape on wires and unplugging this is how I did it..lol
As fuse box labeled so u can replace them easily.
Also when you have lights on high beam and heater on rear window demister and radio how bright is your dash light glowing? Mine well blinds you..lol And I have a KE30 and well I installed spot lights and a sub so I can't rn everything at once so I am upgrading the alt but if your light isnt glowing much A your alt is GOOD or B your alt can't sense the right power the batt has to charge right.
Just a thought.
Cameron
