Was the TE72 made in japan (imported to AUS like the KE70 panelvan)
Was the T-50 manual used in the TE72??
Would anyone have any pictures of a TE72 manual gearbox x-member?
I would like to know the dimensions/distance between the bolt hole centres??? :ninja:
Edited by SKA80R
You posted Here
sorry about that.. i thought i was in the write section
Can you tell me who is a TE72 expert?
My car is a JDM ke70 and i need to know if the TE72 was JDM (imported to AUS).
None of the KE70/AE71 gearbox crossmembers fit under JDM KE70
I thought if the TE72 was JDM...there was a good chance the x-member might fit
Edited by SKA80R
Couldnt you just check the firewall plate on your car if you're uncertain of the gearbox you have?
Correct me if I'm wrong, but I thought the T-18's (TE72) came out here with the3T-C motor and T-50 gearbox.
So I thik you would need either an AE86, AE71 or T-18 bg x-member.
But that's what I think.
Unless yours in an import with a different gb.
te72 uses a t50 gearbox however the clutch slave is on the drivers side unlike the common t50 with the clutch slave on the passenger side.
ke70 came with a k50 gear box. you will need a t50 cross member for the new gearbox and also need to update the ke70 to hydraulic clutch.
yes te72 came with 3t-c engine.
don't know if it was an import but pretty sure it wasnt since it was released in aus as the t-18
Thanks for the info.Do the compliance plates have japanese writing on them? or are they made by AMI
My car is a KE70 Panelvan made in Japan (Japanese compliance plate)
I am using a T-50 from a AE86.
I have tried using the following x-members AE71 and AE86 so i thought the TE72 might fit
Here is a pic of some cross members
Jap Ke70
Aus Ke70
Aus AE71
