Taz_Rx Posted June 3, 2013 Author Report Posted June 3, 2013 As my tuner reiterated last week he has never heard my engine ping, and that's with >15 psi and a heap of timing. If we got to the point with 8.5:1 that out was starting to ping a bit that's when I would look into the water/meth more. I do plan on running around 25 psi when I get a turbo reliably capable of it. Quote
kickn5k Posted June 3, 2013 Report Posted June 3, 2013 What are your idle and cruise mixtures like? Can usually chase them pretty lean. Does your wolf have a "lean cruise" map? Quote
Taz_Rx Posted June 3, 2013 Author Report Posted June 3, 2013 After the comp raise its obviously going to need a re-tune, but we'll also look at activating the closed loop control.....which I'll have to get an o2 sensor for. Quote
oh what a nissan feeling! Posted June 4, 2013 Report Posted June 4, 2013 Your tuner will be able to tune to prevent any detonation usually up to about 24-25psi on most alloy head engines with pump 98 fuel. Fuel becomes the restriction after that which is where your water meth, or tolulene, or e85 comes in. The new gtx28/63 is supposed to be an awesome turbo, probably the best of the whole gtx range, so if you do end up spending up or chasing larger powers check that out. Quote
Damon550 Posted June 4, 2013 Report Posted June 4, 2013 closed loop control is great i'm drawing air through the sc12 and still getting 8-9L per 100km Quote
Taz_Rx Posted June 6, 2013 Author Report Posted June 6, 2013 On 6/4/2013 at 12:18 AM, oh what a nissan feeling! said: Your tuner will be able to tune to prevent any detonation usually up to about 24-25psi on most alloy head engines with pump 98 fuel. Fuel becomes the restriction after that which is where your water meth, or tolulene, or e85 comes in. The new gtx28/63 is supposed to be an awesome turbo, probably the best of the whole gtx range, so if you do end up spending up or chasing larger powers check that out. Had a look at the new gtx turbos this morning, tbh I don't think the compressor housing would fit down next to the chassis rail! The t28 one it pretty damn close as it is. Noticed they now make a disco potato with a stock sized t28 front cover though, for straight swappage on an s15...that would fit! Quote
untubbed_20 Posted June 7, 2013 Report Posted June 7, 2013 (edited) Mine had 7.00 i reckon..lol ..horrible I dynoed my stagea with water meth on thurs...17psi of boost , timing went from 20 degrees at full load and slightly pinging on 98..to 30 degrees...lol the whole map copped 10 degrees more timing actually and 40rwkw+..and no heatsoak... if you wanted a turbo..id talk to stao at hypergear, he might make something up..i woudn't bother with gtx stuff, lol a k motor would never swallow that much air to use those wheels and I'm pretty sure all the t28 gtx stuff is not real great anyway even on bigger motors,not enough turbine Sure the tuner can run 23-24psi on 98..lol, pulling out all the timing...and then pull out another 2 degrees on top of that to account for heatsoak of a non crossflow head.. cheers darren Edited June 7, 2013 by untubbed_20 Quote
untubbed_20 Posted June 8, 2013 Report Posted June 8, 2013 (edited) Stao at hyperear can make up a billet wheeled 64mm comp wheel turbo, he calls it the ss1, in a .48 T25 housing, and you can swap out to a .64 aswell. think its hks 2530 in flow with billet comp wheel a cam in the 240's @.50 for the street, or if you want to set records 255@.50..lol and some extra fuel octane and it would be a beast..lol cheers'darren Edited June 8, 2013 by untubbed_20 Quote
Taz_Rx Posted August 5, 2013 Author Report Posted August 5, 2013 So I've got about 2 hours worth of work to get it back on the road. Head has gone from 33cc to 23cc chambers. Hopefully get it tuned some time next week. Quote
Taz_Rx Posted August 5, 2013 Author Report Posted August 5, 2013 That's pretty much a lazy 2 hours with a couple of smoke breaks....interruptions from missus and kid, you know the deal lol. I got've all the manifolds, turbo and dump pipe already bolted up to the head, its so much easier to do it that way than in the car when you've got the head off. The stud next to number 3 ex port is an absolute bitch. So my list really just consist of: Drop head etc on and torque down Get under it and do the oil return, 1 water line and the exhaust Couple of fuel lines Wiring loom on Cooler and intake pipes Radiator in and fill Buy new plugs and put them in knock 5 degrees out of the whole map until I get it tuned Start! ....so really less than an hour solid. LOL Quote
Taz_Rx Posted August 5, 2013 Author Report Posted August 5, 2013 On 8/5/2013 at 9:48 AM, Trev said: That's a good go in 2 hours. Not really, everything is pretty quick and easy. Forgot to put adjusting tappets on the list though. Radiator takes about 5 minutes and all oil, water and fuel lines are speedflow. Quote
kickn5k Posted August 30, 2013 Report Posted August 30, 2013 Hows the comp increase treating you? Quote
