haha. Sean's on the case.
Yeah well put it this way.....it now has oil and water in it!!! ;) so I'm soooo close now.
Forgot I still need to get another cable from Wolf. otherwise I could have had it running.
Powered it up after Sean left, couple of things I noticed that'l need some attention was the fact the fuel pumps weren't working, and I wasn't getting an ignition pulse - but this may be cuase its set on something else like coil negative trigger.
Also, must need re-calibrating as the map sensor thought it had 0.1psi on it and was flashing the boost light! :hmm:
Looking really good though! re polished the tappet and inlet again and its "Pretty" as the missus said! |blink|
You'll have to wait for pics. :)
Yeah will order it tomoz mate, know a couple of people with wolfs, so I might be able to borrow one in the mean time. |blink|
If youve got a hand controller you can get it running.
Its really easy.
Matt
that tappet cover looked overrated today si you could really see yourself in it, just need that cable. meh! what a bitch of a project! all coming together slowly. i so shotgun first ride in it!!!!!!!!!!!!!!!!!!!
Edited by roids70
I might give you a call tonight Matt. Mainly need the cable so I can load your maps on.
I'll take so piccies today...along with the wagon, which I'm about to go pick up! |blink|
Will start a new projects thread for the wagon once I've posted pics in this one and photo bucket has done its thing. |blink|
All that needs to be done now is:
Exhaust
Cooler piping, maybe a BOV too ;)
Throttle cable
Load maps and tune
Actually found a throttle cable this morning when Ben and I went rolla shopping (he bought a granny spec k'sev today) at franks/marks. It was in a V6 pajero and its uber long, so I reckon I could hide it pretty easy.
Ok, heres a couple of pics of the 80% complete engine bay......
Exhaust
Throttle cable
Load maps and tune
What do you mean "maybe a BOV"
Its a necessity man.
MAtt
Funds pending! |blink|
Would really like a turbosmart one, but that means the I'm another $250+ off finished.
Thinking I may use another stock rx7 one as a very temporary thing, and do it in such a way it can be swapped out for the turbosmart one easy.
Funds pending! :S
You gotta have it man,if you try and get off the gas at big boost it will tear that comp wheel right of the shaft if you don't have something.
Oh forgot to comment on how good thoise injectors look!!!!!!!!! :y:
Matt
Edited by madrolla68
