hey guys ard girls, just a few quick question,
I'm in the middle of rebuilding my ke20 and I'm wanting to purchase some RS watanabes. just wondering what i could fit under the gaurds size wise. was considering 15x7 with 21+ offset. wondering if i could run these or even 15x 7.5/15x8
cheers, tom
15x7 +21 is almost spot on for front and rear to fill completely under stock guards.
Add an extra inch on rim width for bead lip and multiply by 25.4 to convert to mm rim width
and you can compare to tyre width and go from there, also sidewall height is a factor.
Edited by styler
Car: 1974 KE20 4 doors sedan
5K 1500 engine with 5 speed tranny, maybe of a 80's Starlet
Stock front suspension, lowered rear suspension, stock front sway bar, urethane bushings all around
Stock drum brakes in each corner, Starlet (80's???) brake booter
5 holes telephone dial 12inch wheels, with Yokohama 165/60R12 tires
Interior and body: in much need of love!
I bought this car from a friend's uncle, the only owner since new. It has no structural damage, only the known rust problems of every KE2x. My plan is to restore it to (I hope) factory condition, but with a few upgrades, like front disc brakes, 13 or 14inch wheels (minilite style) and reinforcements bars under the fenders, in the engine compartment and the trunk, so it can gain structural stifness. I'm planning a full body and interior redo for the next year, with a new color and materials, and new rubbers (windshields, door's glass) as well.
Car: KE20
Will have...
Motor & Driveline: 4AGE Blacktop, T50 box, not sure about which diff yet but a 1.5 way
Suspension & Brakes: Full S13 running gear/subframe, fully independent suspension. Japspeed adjustable arms, Eibach top camber bolts. Custom coil overs
Wheels & Tyres: Rota Grid V's in bronze
Interior: Recaro fishnets
Body: To be glass beaded and have fabrication work where needed
Other: Lots!
1 by mewhitenoise, on Flickr
Managed 60.3bhp on the rollers from the stock 1.2 ^^
2 by mewhitenoise, on Flickr
3 by mewhitenoise, on Flickr
4 by mewhitenoise, on Flickr
Here's a more detailed blog of what's been going on..
http://www.southwale...-pic-heavy.html
Front end's now been mocked up, and work's being started on the back end as we speak. As I'm a poncy mac art worker, my Bro's the mechanical wiz so he's doing most of the work and I'm um.. handing stuff ;-)
photo 1 by mewhitenoise, on Flickr
photo 2 by mewhitenoise, on Flickr
MIG stitch welding the floor pan by mewhitenoise, on Flickr
Edited by MeWhiteNoise
  • Upvote 1
Car: 1974 toyota corolla deluxe
Motor & Driveline: 1.6 2tc automatic
Suspension & Brakes: all stock
Wheels & Tyres original tires from 1974
Interior: black all original
Body coupe
Other: has 038,000 original miles , 3rd owner, all original condition , unrestored
Edited by goofesgts
  • Upvote 2
Car: 1973 KE20 Corolla
Motor & Driveline: 1.3 4K
Suspension & Brakes: KE25? disc brakes in the front, soon to add 1.5" blocks and 'low' King Springs
Wheels & Tyres: Some random euro wheels off a Saab or some shit.
Interior: Black with bucket seats
Body: Sedan
Other: Rebuilt 4K, fully sick sub woofer, 10 degrees advanced timing, 1 3/4"exhaust, mad 6ft aerial for shits and gigs. Oh and an AROOOGAH horn.
Cody
'74 TE21
Stock 2T-C
T3 strut tops Ground Control coiovers
Steelies and studless snow tires
Stripped with Subaru WRX front seats, GT wheel
Straight with not much rust, coat of primer and fender flares.
Just recently picked it up and been sorting it out. Have a lot of plans for it.
574717_4238324963616_340243083_n.jpg251981_4217676087407_863231406_n.jpg406206_4217677687447_2081981669_n.jpg
Oh i forgot to be in here....... :doh:
A new peanut....
Car: 1975 toyota corolla Hi-Deluxe
Motor & Driveline: 3k 4 speed manual
Suspension & Brakes: all stock (front disc, rear drum)
Wheels & Tyres : 12" Alloy wheels with 155/12 tiny tires ..
Interior: Woodgraine dash and black interior with original Hitachi Air conditioner
Body 4 door sedan/saloon
Other: 93k kilometers in clock , 4th owner,original condition and recently restored
  • 2 months later...
Name: Justin Car: 1973 ke20 2 door sedan SL rally/track car
Motor & Driveline: Worked 4k 4 speed manual
Suspension & Brakes: Stock rear corona front struts and breaks
Wheels & Tyres: Datsun bluebird TRX rims with Achillies 123 R-specs and Corona rims with Cheapo tyres
Interior: 6 point cage, Autotecnica monza evo bucket seats, 2" autotecnica 4 point harnesses
Body: 2 pak full repray in the original mocca brown and has some signage
Other: This beauty was bought in 2006 by my dad and brother for a khanacross car, after 2 races my brother lost intrest and i was keen to take over. once i turned 14 and was able to drive in the khanacross i got stuck into the car, it was only ever a bit of fun but over time has become my life (mum's sick of hearing about it). First I fixed the rust in the front quarter smashed out the dints, flared the arches and repainted them. Next was the cage followed by a tidy up of the dash and door trims etc, then the car got a full respray (back yard job) and covered in stickers. We pulled out the 3k and wacked in a 4k. the 4k has been completely rebuilt, 20 tho oversize, new pistons, rings, bearings, full gasket set, new valves, valve seats and valve springs, port and polish, retuned dizzy, 10.5:1 compression, twin 40mm side draft webers, 4-1 extractors and a 2" exhaust with a hotdog. Revs to 8,000RPM and sounds awesome. Made 45.5rwkw on the dyno with 9.8:1 comp and I haven't had it on a dyno since putting the comp up to 10.5:1 but it made a huge difference so I'm guessing 50-55rwkw now. I am currently rebuilding a big port 4age for her to go in over christmas with a t50 and ta22 axel.
  • Upvote 1
  • 2 months later...
[B]1974 KE25 COROLLA/B]:
[B]Original 3k with 2 speed auto box.[/B]:
[B]stock breaks[/B]:
[B]ke25 hubbies[/B]:
[B]Brown, couple tears here and there, all in good nick otherwise.[/B]:
[B]pretty straight, has a dent on the bonnet and one on above the drivers door handle.[/B]:
[B]Everything is original, just a nice, clean stockie. Was a farm find. Has been in the garage for minimum 10 years..[/B]:
Car: KE20
Motor & Driveline: 3TC and 2-way TRD LSD
Suspension & Brakes: RT130 front struts,
Wheels & Tyres: staggered Compomotives in 13x7.5/13x8
Interior: stock
Other: to many to mention.. :)
Edited by Longhorn
