gemless Posted November 18, 2006 Report Posted November 18, 2006 i have done a search but have not found the answers i am looking for. *is there a difference between the small port, blue and red top age4s?if so what are they? *were the small ports released in australia?if they were what would be the difference between a aus one as compaired with a jap inport? *would i find a lsd in a jap import gear box for a 4age? any help would be great thanks brett Quote
Jono Posted November 18, 2006 Report Posted November 18, 2006 small ports are 100kw big ports are 86kw and have TVIS small ports were in ADM SX corollas not sure if the JDM small port is any different but keen to know as mine is an import. Quote
gemless Posted November 18, 2006 Author Report Posted November 18, 2006 i think that a blue top is a big port red top is small port could someone explain *ADM SX corolla? *JDM?is JDM import engine? thanks brett Quote
towe001 Posted November 18, 2006 Report Posted November 18, 2006 gemless said: i think that a blue top is a big port red top is small port Yes and no cause the cam covers fit either motor. So does the heads.......... Quote could someone explain *ADM SX corolla? *JDM?is JDM import engine? thanks brett Australian Domestic Market - A car (or something) thats sold in australia. The SX corolla is the twincam (4age) version of the ae92 corolla. Japanese Domestic Market - A car (or something) thats sold in japan. Quote
gemless Posted November 18, 2006 Author Report Posted November 18, 2006 on the big port head the words "16 valve" is written in blue and on the small port head the words "twincam 16 valve" are written in red. so what is the difference between the jdm and aus small port 16 valve? thanks brett Quote
towe001 Posted November 18, 2006 Report Posted November 18, 2006 As far as i know, nothings different. Their both the same motor. Possibly the only difference would be the ECU since japan has higher octane fuel. True with the cam covers. But do remember, only take that as an idea to what the motor could be. Cause, like, one that i've got under the house has redtop cam covers but its really a bigport motor. Quote
gemless Posted November 18, 2006 Author Report Posted November 18, 2006 (edited) would the different ecu give more kw? the tvis plateis anther way to tell port size. why is urs big port with red words?did some one just swap covers or its a later model? Edited November 18, 2006 by gemless Quote
towe001 Posted November 18, 2006 Report Posted November 18, 2006 gemless said: would the different ecu give more kw? You'll be better off looking on toymods cause there was a thread or two on the subject a good while back. Quote the tvis plateis anther way to tell port size. True. Quote why is urs big port with red words?did some one just swap covers or its a later model? I got the motor from a mate, and we both thought it was a "between" version. It was a version that used the bottom end from a small port block, big port head and redtop cam covers. But i finally got around to pulling the sump off and its just another big port motor. So i'm guessing the cam covers had been swapped over before me mate bought it Quote
Medicine_Man Posted November 18, 2006 Report Posted November 18, 2006 gemless said: i have done a search but have not found the answers i am looking for. *is there a difference between the small port, blue and red top age4s?if so what are they? *were the small ports released in australia?if they were what would be the difference between a aus one as compaired with a jap inport? *would i find a lsd in a jap import gear box for a 4age? any help would be great thanks brett Pretty sure smallports all have red cam cover lettering "red top" but to confuse you even more AW11 MR2's have "red top" bigport heads.. The red lettering is probably a better indication that the block is the later "7 Rib" block.. yes the smallports were released in the AE92 SX Corollas, A Jap 100KW motor may have a better tuned ECU as the Japanes fuel is better than the shit we get over here. Pretty much the same as the Aus 86KW and the Jap 88KW 4AGE tuned ECUs.. Possible to find the LSD but somewhat rare from what i understand? Quote
love ke70 Posted November 18, 2006 Report Posted November 18, 2006 http://home.clear.net.nz/pages/phil.bradsh...0into%20RWD.htm http://www.billzilla.org/4agstock.htm Quote
gemless Posted November 18, 2006 Author Report Posted November 18, 2006 so if i look at a motor with no tvis plate and red writing does this mean it is a small port 7 rib block? all confusing. thanks brett Quote
Trev Posted November 19, 2006 Report Posted November 19, 2006 (edited) There are actually 2 versions of the bigport (As Medicine_Man pointed out before), The "Blue and Black Top" (3-rib block) and the "Red And Black Top" (7-rib block) both been identified by the TVIS badge or you can identify them by the spark plug cover (will get to that shortly). 86kw Blue and Black top bigport 3-rib (AE82) - 1st generation: 86kw Red and Black top bigport 7-rib (AE92 '88) - 2nd generation: Now it comes to the smallport 7-rib 100kw engine which can be identifed by the plain ribbed inlet manifold and the spark plug cover: 100kw Red and Black top smallport 7-rib (AE92 '89) - 3rd generation: This should be able to expalin it quite easily as to what engine you have, Are you able to post a pic of it at all. Edited November 19, 2006 by Trev Quote
gemless Posted November 20, 2006 Author Report Posted November 20, 2006 thanks mate the pics really helped.i defently hav a 3rd greneration 100kw. thanks everyone Quote
Trev Posted November 20, 2006 Report Posted November 20, 2006 gemless said: thanks mate the pics really helped.i defently hav a 3rd greneration 100kw. thanks everyone No worries mate. Quote
