demuire Posted July 2, 2004 Report Posted July 2, 2004 Hmm, that is true, you might lose a bit of clearance between sidewall and strut when the strut is bent. I'm not sure if they do it on the car, I believe they do. Quote
Redwarf Posted July 2, 2004 Report Posted July 2, 2004 Fook, 45 psi reduces side wall flex. Used to find scrub marks almost to the rim. Apart from that, I dunno, it just seems to work well. P.S: Bending the struts is called camber correction. :) Quote
demuire Posted July 2, 2004 Report Posted July 2, 2004 Rob: I don't seem to have that problem much on the front, mostly in the back. When I was running the Simex SM6000 tyres even with 48psi in the rear I was still getting scrub marks almost to the rim on the back wheels (going around the Paperclip)!!! Quote
