Hey guys, i recently bought a gemmie wagon and just discovered that it has air horns in it. But ... the airhorns don't work. They are connected to a button next to the handbrake "stealth" style and when the button is pressed nothing happens except a clicking noise from the compressor thingy thats comes with the horns. Does anyone know what this problem could be. Just run out of air?? or totally f@$ked? it isn't a big deal i just rekon itd be hilarious havin an airhorn.
or anywhere that fixes these kind of things
Cheers Beau :)
Edited by Beau-Jangles
Start the car and hit the button and see if the compressor pumps any air at all ?
Take one of the horns out and blow into it as hard as you can and it SHOULD go off a bit.
If its pumping air to the horns and no noise they are probably f**ked.
Des :) :)
Yeh i looked at them closer. There is no air being pushed into the horns. It just clicks over. Is it possible to get them "re-gassed" or whatever. Maybe an electrical fault. Who would know how to fix this shit. Auto electrician??
