Search the Community
Showing results for tags 'multi spark'.
  • Search By Tags
    • multi spark ×
    Type tags separated by commas.
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. If your looking to run a cdi type box like msd there's a little issue with the internally regulated distributors for k motors It's common knowledge we use the original dizzy wire and we add a coil positive wire for the electronic distributor. If you use an alternate ignition source for that...
