Search the Community
Showing results for tags 'low compression'.
  • Search By Tags
    • low compression ×
    Type tags separated by commas.
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. Recently fitted reconditioned cylinder head with VRS kit to 2000 1.8ltr 7a-fe corolla. Engine runs but pushes oil out rocker cover/cam seal (a and b in images) Cylinders 2 and 3 have only 60psi. 1 and 4 have 180psi. Piston rings??? Please advise possible causes and remedies.
