Search the Community
Showing results for tags 'ignition problems'.
  • Search By Tags
    • ignition problems ×
    Type tags separated by commas.
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. I’ve picked up an 82 ke70 4K and the previous owner has done some dodgy wiring. Looks like the main harness has been cut as well as lots of other dodgy stuff (pictured). When I try to crank the engine about 50% of the time I just get a little click (like when the battery is dead flat) and then the o...
  2. I did post this in non Toyota, but that doesn't show up in anyone activity feed, so i got 0 views over 12 hours. I have a question for those with points type ignitions. My GFs dads car is playing up a bit when cold. IIts a suzuki Multicab wiht a 3 clinder 12 valve engine. Has a nasty missfir...
