Search the Community
Showing results for tags 'Ke55'.
  • Search By Tags
    • ke55 ×
    Type tags separated by commas.
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
  1. Hey guys Just wondering if anyone knows where to get new Stock front shocks for a ke55 Sedan, I tried lots of shops around Sydney they all offer the Monroe-matic Plus part number 805014MM but they did not fit in the inserts unfortunately they were too long and thinner and original shocks, any help w...
  2. was just wondering about something posted in a thread: "15x7 with offset between 0 to +10 is spot on for KE's". I'm looking to upgrade wheels on my ke30, currently have some Tarago steel wheels 14x5.5 +30 (measured offset myself so hopefully its accurate) on stock standard (AFAIK) suspension, an...
  3. G'day guys I'm looking at changing the current drum brakes on my KE55 to a disc brake setup front and rear. any ideas on the best options. DW about price just want a safer and better car for myself on the daily.
  4. Hi all, I have this nice beauty of a car, good old ke55 4 door sedan. Nice Toyota yellow with a mint condition interior. 4k-c engine with k40 gearbox. Been doing my own bits and pieces here and they're. Plus some added mods to give me classic extra grunt that is so much needed. So...
  5. Hi all, i am up to the point were i want to start wiring my Sr20 engine harness to my ke55 body loom, for those of you who have done it or know whats required able to fill me in with what wires i need to connect to get the motor running, also have an external fuel pump which needs to be connected to...
  6. Hi everyone! I've got myself a 1980 ke55. When I bought it it had all the usual corolla rust (rear wheel arches, boot, etc.) But when I started rust repairs, i found previous rust repairs. And bog. Lots. Of. Bog. Anyway to cut a long story short, I've decided to keep her and turn her into an ab...
  7. A couple of years ago i picked up this KE35 here in the philippines. Pretty much it was just covered in rust and had just two passenger side seats and cheap carpet glued all over the place to cover up the rust. I figured It would be a good project for me to work on my body work and welding skills. t...
  8. Hey everyone. I've been a member here for almost 7 years, been using your wealth of information even longer. Thankyou to everyone who has contributed. The information on here makes everything so much easier. Yet at the same time so much harder due to deciding which way to go. So after buying my R...
  9. Hey guys, Working on my 79' Corolla. Previous owner has replaced the 4K-C engine with a 3K engine. Everything is connected correctly and have checked everything 100 times. Now, everytime i start her up, she runs well but as soon i put her in drive it stalls. Been trying to adjust the idle...
  10. Hi everyone, the corolla you can see in my pictures, the bluey greeny ke55 is starting to blow alot of smoke and the engine is being a right pain in the arse ever for a 4k with 180,000km on the clock. decided to do an engine conversion on it, but I would like people with more experiences advice. Wha...
  11. hey guys, just curious how much work is involved in swapping my 1981 ke55 rectangle headlights for quad headlights like in the ke70 corollas. i know i need lights brackets and the grille. but wondering if it will all fit. thanks in advance
  12. hey guys, I'm from melbourne, so ive had my ke55 for about a year now, ive been doing a bit of research on converting my stock 4k to a 4age and making it manual, i have no idea where to start, its currently on club rego in VIC. i know ill have to get in engineered, can someone give me a few tips ?...
  13. Hey fellas, i have finally got my ke55sr near complete but running. I took it for a drive and drives well but there is a constant whirring sound when i am idling with the clutch disengaged. I have removed the clutch rod from the pedal and noise is still there. When i depress the pedal the noise goes...
  14. Hey fellas, i have finally got my ke55sr near complete but running. I took it for a drive and drives well but there is a constant whirring sound when i am idling with the clutch disengaged. I have removed the clutch rod from the pedal and noise is still there. When i depress the pedal the noise goes...
  15. o.k. here I am, relatively new to the forum, first post. I was working for a vehicle restoration company early last year when I got offered this KE36 for sale, at the time I was 16 and although I was interested garage space at home was lacking, I joined this forumn however in the hope that one d...
  16. Hey fellas, wondering what you guys have used as a clutch master cylinder in an Sr conversion in ke55. It's a pretty tight space so I can't use the standard Sr clutch master as it will stick out way past the intake mani. Have heard about the ta22 but not sure dimensions and compatibility. Cheers
  17. Hey fellas, I'm about to install my clutch master in the KE55. I purchased an S13 clutch master and going to be mounting to standard ke55 manual pedal. Does anybody know the best way of measuring and positioning or has anybody done this before and have a drill template?? Cheers
  18. Hi guys, have a 1980 ke55 and I just took the motor out and replaced it with one from a ke70 while using the ke55 cam, carb, distributor, head etc. Has new coil, points, condenser, cap, rotor, leads, seals, headgasket etc. Timing set to 8degrees btdc, points set to 0.4mm, valve clearances set cold...
  19. Hey fellas, Another question about me old conversion. Trying to figure out the best way to run a clutch cable to my sr trans. Would you guys suggest buying standard clutch cable and modifying or any other ideas from the guys who have done it before?? Cheers
  20. Hey guys, I'm in the middle doing an Sr conversion into my ke55 and I'm trying to figure out what's best for fuel system. Whether to use inline or in tank fuel pump. Which one you guys recommend. Also what size fuel line for feed and return. Cheers
  21. Hi everyone I'm new here on rollaclub.com and wanna begin my adventure with classic Corollas. I have some project on my head that I'd like to get advise on. Basically I was wondering if KE55 Liftback and KE55 Coupe have the same bolts patterns so it's possible to swap their front ends: hood, gua...
  22. Hi Fellas, I've been trying to figure out which radiator will fit in my KE55 with Sr20de. Measurements for s13 radiator if i set it hard up against the front would be too high for bonnet to close. Are there any alternatives with correct inlet/outlet orientation that will fit or should i try and...
  23. Hey guys, My spark plug tubes are worn through at the plug end and no longer seal at the top because nothing is holding them down. Does anyone know part numbers or who might supply them etc. Much appreciated. heres a vid of my KE55 after powerspark ignition mod, and DIY 2 inch exhaust i wel...
  24. Hey guys ive been reading through all the forums loking at all your engine swaps, I love my ke55 but the motor has shat it self bent 2 rods and snapped 1 would It be better to rebuild the top end and where do I get the parts if so ? Also would it be better to replace the motor if so what is the bes...
  25. G'day So I've got a '78 KE55 Liftback here, and am in need of a replacement rear left window. The problem: I've tracked down a piece that looks like it will match, but it's being sold as a KE50 part- can anyone tell me if this will fit? Having a bugger of a time finding out. Cheers!
