azzy_10
    161
Everything posted by azzy_10
  1. Please post on your r31 diff set up and pics please and the shortening of the diff how much on each side
  2. Got any clear pics on your r31 diff conversion
  3. Pictures please yes I got plenty of power to come through the drive line yes I'm keeping the lowers for traction and mount the the pano rod But really want to see
  4. I got a r31 diff going into my car but want to see some pics on how people have set theirs up with leaf springs
  5. Putting a r31 diff in my car could you post some pic of yours up just as a view on how yours is set up
  6. Mainly for 5-mge
  7. 5m-e or 5-mge
  8. I getting a mx62 wagon want to know what box the manuals are
  9. Is it just GE sigma or any others modles?
  10. what has a bigger bore size the australian master cylinder or the import standard master cylinder for ke30/55
  11. as i see looks like you have an oil cooler on your motor could you please tell me what you did and needed for the job would be great cheers
  12. wants to know what seats can i use in a my ke35 wants somthing with more of a bucket seat that will hold me better through corners help please
  13. id change the thermostat andhousing and check the radiator isnt blocked and a new rad cap too eficcentcy i just got a thermo fan chucked in just on a toggle switch in the car butim looking a extractors as the standard hot box intake exhaust system is heating up my fuel and evaporating it before it gets to the engine
  14. might just have to do local spec brakes 12.7mm db144 discs and db1088 pads
  15. Need brake upgrade my import stock brakes fade out when i give her a thrash through the hills i got Standard sumito calipers and the 10mm thick discs need a shove in the right way Cheers SLW992
  16. old 4 spd was accurate just this 5 spd isnt and i have to keep the gps on charge all the time ill try new gears soon
  17. yeah but i want an acurate spedo thats says I'm doing a 100kph not a 120
  18. hi all just put a ke70 5spd in my ke30 and my speedo is out 20kph out when I'm doing 100 it says I'm doing 124kph at a 100 from my gps wanted to know can i change my speedo gear from my 4spd will that work
  19. Cylinder head
  20. They took off 8 thou just to get it flat and heres a pic Needs to know how much needs to be taken off
  21. well its a the work shop atm but getting it shaven flat then taking how ever much off was guna get 5thou off
  22. how much do i take off the 4k head to match the compression
  23. how much do i need to take off to get it to 3k-c 8.5-1 compression and is it still to buy 3k head gasget?
  24. i got my 3k engine and i got a 4k head I'm trying to do a head and gasget over the weekend with out taking time off work am i right to say the 4k head is a de compression on a 3k-c engine ?
