KESR20
    61
Everything posted by KESR20
  1. Awwwwsome , i just wasnt sure, even tho i work at supercheap like once every 2 weeks i always see it and I'm always wonding if u can use it which primer did you use? theres so many , and i don't no what i need exactly? does the spray go in order like this? bog it up etch? pirmer filler? acrylic white? then clear? i do know that the paint has not been thinned from factory, so do i mix 2 parts thinners 1 part paint? and with that mix in mind will it stick too the car without any like type of formula u need to mix with the paint with a glue or sumthing.. sorry if i sound dumb. but i just want too be sure! and I'm not big on painting books.. for the 50 it will cost me i can get the first 2 tins of paint or a spray gun :P thanks anyways i did have it in mind tho
  2. Hey I'm just doing a DIY paint job on a corolla ke36, and was wondering if anyone would know much bout it.. I'm planning on using super cheap auto acrylic white with there etch and primer surfacer or filler over the top of the etch, What i was wondering is do i need too use paint thinners too thin out the paint from the tin? and how much am i supposed to thin it out if need be :y: cheers also if its ok to use a low pressure automotive spray gun:) cheers fellas
  3. You can weld stainless steal too metal n vice versa, its when u try aluminium too other metals. stainless is just metal in a altered state so ofcourse it can be welded! i love looking at stuff welded like that, because after a few months of oxidization you see whats what hahaha
  4. gaahhh whats cheaper.. cuz i can weld up sum stuff n fabricate a manifold?
  5. wow awsome dude, so no bigger than 35, what will this upgrade n will it handle any different?
  6. Hey , just recently i found a bunch of clips of people who have 4 motorbike carbs on there 4 k motors and other various motors, is this practical and does it work well? also how do i know what size carbs will fit on my 4k motor?
  7. its like when you drop the clutch and it bashes hard... like u can rev it and it wont move, then all of a sudden it will put itself in gear and its so rough and feels terrible
  8. cmon, anyone!
  9. Hey guys, i bought a second hand hilux and the auto in it was running smoothely up untill recently where it is a slow poke at gear timing and it rolls back on hills that are like nothing for it before? and when i go from drive to r or vice versa.. it bashes really hard. any suggestions
  10. Hey peeps, Just after some general knowledge as too where i might find a engine. And only a engine(4age). i don't want too get a half cut after realising that i wont use most of the stuff and alot of custom work will be going into it! Everytime i look for the motor i get half cut ads.. and its ennoying as! so any help would be apretiated1
  11. Hey everyone, Just enquiring if anyone knows where i can get superlow front springs for my ke36 wagon, and if anyone knows what i cud do otherwise to lower it legally, let me know please :hmm: thanks
  12. i don't no ill see how i go, i no that these are the simplest things too make , i don't have the car yet, thats why i was planning on getting everything ready by then, but i guessilll have too give it more time.
  13. nah no luck for me , another reason why is i don't like my work , not saying its bad but when someone else does it i can put all the weight on there shoulders if it gets damaged n what not
  14. hahahha well if they hold up , and will pass and work ill take em off your hands
  15. I'm in brisbane, but ill pay postage aswell, reason i can't bf to make these mounts is its time consumming on my behalf and i wont have much time trying to do the other stuff.. if its possible tho for some plans of the mounts ill happily take those off your hands :)
  16. where are you located and how much are you selling the mounts for? I'm totally interested! you must be doing some legendary stuff to make all these mounts :)
  17. wow thats tops man cheers! with a half cut would i still need to tune the thing on a dyno? or will it be ok with the stock ecu and all
  18. Looks sick, can't wait too see the final product!
  19. Hey all, In the next 3 or 4 weeks I'm planning on begining my build starting with rust repair and overall stuff I'm after engine mounts too either suit sr20 or 4agze to fit into my ke36 wagon, where would i get drawings for these ? Or would anyone be making or selling theres? ive called some shops but no reply so i believe there abit lazy.. I'm in no rush for the engine swap, but i would like too get the main stuff that i need to get the motor and gearbox too sit perfectly! and also would it be wise of me to find a half cut for these motors. or begin from scratch and buy all the indevidual stuff? thanks
  20. hey man, with the sr20 mounts, will they work with a ke36? same with the box mounts? if you are I'm buying
  21. Hey everyone! just ben looking into options for lowering, and i was just curious how low i need to go to get the back wheel in the guard by about 3 fingers wide, sorry but its just roughly how long the distance in the guards ide like it too be. also what would the go be for the front wheels? just superlow king springs? And will i need to do any guard rolling in this too work successfully? thank yous all in advance :P
  22. while were on topic of diffs, i want too change the dif out on my ke36, reason being is I'm after more acceleration out of the car, what dif do i put into it? its manual btw if that helps
  23. hey what type of paint did you use for the bodies primer, and what type of paint is that blue! where can i buy it from?
  24. well i got a few peeps too help, i can weld in all fields so thats a plus,and dads a engineer/boilermaker so i could be having some real fun with this one
  25. that shud be ok hahaha its a car, its not meant too be too cheap in the end
