Ok guy here's the story I've got a 4AGE bigport in my KE70, it has had the engine in there running 1.5 years ago then we pulled it out. Have recently got it back in and running. When we first started it there were some issues starting, got it sorted turns out the coil was not happy and we changed it and it was running great for about an hour... We jacked up the back end to put the new tailshaft in and wire the thermo fan back in and now it doesn't want to run.. We unplugged the MAP and it started and ran, rough but it ran, would not rev over 4500 rpm. When we plug the map in when it's running it idles great won't rev and then it stalls about 4 seconds after reconnecting it. It almost sounds like misfire and not getting enough spark which was the problem before. I tested the relays and fuses and they are all okay. I can't work it out and the manual keeps leading back to electrical problems as to why it won't work..
Bought a new map and that didn't fix it. thought about getting a new TPS but I keep ending up with the same conclusion, Igniter or spark problems, Any ideas or help would be greatly appriciated because I want to get it running again and driveable.
