40 -
Everything posted by rowantsarolla
Thanks for the replies guys. Pretty bummed! There aren't any other explanations for this problem hey. Well, is a bent strut unsafe, even if I ran lower offset wheels? Would like to get it fixed, but don't have the means myself. Any idea how much it would cost to fix the strut once I confirm bend?
Are ke20/ke25 struts different, because even on the standard strut there is hardly any clearance, and yet previous owner assures me that there was lots of clearance on his ke25 (no spacers used). They are pretty high offset, but I thought they would fit my car based on the 25.
Hey Rollaclub I bought a set of wheels that were run with no problems on a lowered ke25, but when I put them on my KE20, the front right wheel and coilover hit. the actual rim presses against the coilover, whereas i have a few mm clearance on the drivers side, and everything is good. All wheels are the same size and offset etc (13x 5.5 + 35 offset), and the coilovers are just modified ke20 struts (weld on coilovers made by previous owner). I tried a wheel on a standard ke20 strut and there was a tiny bit of clearance (<5mm from the tire). So this problem is only in one corner. All i can't think of is bent strut, but it doesn't look bent. Is it possible to change the angle of the hub any how? HELP?
Help Me Get My Barn Find Ke20 Back On The Road!
rowantsarolla replied to rowantsarolla's topic in KExx Corolla Discussion
Thanks parrot! Only things in that list I haven't done are reconditioning ANY brake system parts, and changing diff oil and wheel bearings. Thanks for the help, I'll try and find my old Gregory's manual (KE55) and hope the processes for the different cars are similar. -
Thanks Peterd, good tips! Of course, I want it to be safe anyway, and ill clean it right up! -
Hey guys/ gals! I am hoping to pick up my KE20 this week, having it couriered to Sydney as we speak, so I haven't seen it in person yet. Excited. This car is going to become my daily driver, but ill need some advice on getting it back on the road. Heres what I know about it so far: -KE20 2 door (unsure of year) -Has been in a shed on a farm in Western NSW since year 2000. - Previous owner pulled it out, cleaned the points on the dizzy and got it started. - It drives (well, apparently) - Manual 3k 4speed. - Standard as far as I know, apart from foggies. -Has minimal rust, but some fairly sized dents (may need new boot lid and FR guard) So where should I start in terms of getting it ready for Blue Slip given that it's been sitting so long? I have access to a spare 4k engine and KE55 Suspension. Should I expect the gaskets to be damaged, parts seized, rust in fuel tank? What would you guys do? Any help super appreciated!
Pushrods Out Of Place In 4K- Valve Clearance?
Thanks so much Altezza! Really helpful guide there! Well I'm not sure that I will modify this one. I just want it to run smooth and to the best of it's current ability and then chase rego. My last ke55 I had a go building a whole 5k with some machine work in the bottom end (reground cam, bigger bore and balanced crank), and the Corolla before I had a go at getting the head machined after blowing the head gasket. These cars are such a good platform to learn on, and a platform I have no desire in going past! I'll do my best to get it running without outsourcing, and then who knows where that will take me. I never really got to experience the fruits of building the 5k as I sold the car soon after building the engine. Thanks for the input! I need it again! -
How would I rectify this if it were the case? -
Thanks guys! I pulled the pushrods back out today and they are straight with no defects. I definitely didn't do the clearances properly! Will make sure I do it properly next time! the previous owner definitely wasn't a thrasher. -
Didn't seem to be? One had almost rubbed through the spark tube tho! Another thing- the previous owner was using lead supplement in the fuel (which sat around for months maybe) Is this bad? -
Hey Rollaclub I just got back into a ke55! When i went over to pick it up from the seller we started it and it just sounded like it was running on 3 cylinders and the engine sounded really loose/ rattly! It drove (with absolutely no power), and we were able to get it home (a 5km downhill drive home). Yesterday I pulled the rocker cover off and saw that on cylinders 1 (intake) and 4 (intake) the pushrods were unseated, hence leaving the valves closed. I had to take the rocker arm off to get them back in, so i have no idea how they came out. I tried setting the valve clearances to spec and they still fell out. Maybe i set the clearances wrong, but could there be another explanation for this? Engine runs better now, but still sounds wrong. any tips? worn cam? valves not retracting well? thanks guys (4kc, solid lifters)
Fresh 5K Making Bad Noises...
Oah ouch. I think I'll have to take the motor back out again and change the pistons then. This gives me a chance to sort the compression out and a little leak in my sump gasket as well as check the cam timing again. Did you have a good method for being sure of the timing? I took the chain off, found and marked the opposite links and lined them up with the timing marks, thinking that opposite is where the marks were meant to be? -
I'll have another listen but that sounds pretty darn close- what was happening there???! -
Hey guys. Finally got the 5k into my ke55 that i had been working on for a while (the conversion). It is running, and drives- but not well and makes a crazy noise. The noise is like a fast tapping/ rattling noise coming from some where in the middle of the motor. Could anyone suggest what the noise may be, and how sinister it may be? I built the motor myself, it has: -5k block with 5k rods, lifter etc (hydro) -5k SHALLOW DISH pistons -5k DEEP DISH head (standard) -4k valves/ springs (standard) -25/65 270* cam grind -rollamaster timing chain kit -4k ancillaries -shimmed oil pump As far as i can guess the noise may be piston rattling or something because of the huge compression. Any other ideas? Also, the motor does not easily rev far past 4000 revs, not that i have been game to push it. I have the deep dish pistons here but i was initially going to use a 4k head, hence going with shallow dish pistons, and want to avoid swapping them out!
I need the dished version, although I swapped to flat top/ shallow dish pistons. I need the shallower of the 2 heads. Man, if you have one I am so excited haha
Hey guys, really struggling to find a 5k head for my 5k build. I have put up a WTB thread, hit up eBay and gumtree, and just about every wrecker within 100km of myself. My question (apart from "do you have a 5k head to sell me!?") is: What other suppliers are there that I could try? I.e, other websites, businesses, companies etc. I heard that there is a forklift that has a 5k- are there new production engines/ parts for them? Any help would be too good, thanks. Ro, 0410 949 385
Help! 5K Assembly With 4K Rocker Gear.
Well I bought the 5k block without the head, and haven't been able to find a 5k head. Do you reckon I'd get away with the shallower head on the shallow pistons? How did you bring the compression down, and what did you get it down to? I have a 25- 65 cam (tighe 104). I will have another read of your build thread! Thanks philby! -
Yeah thanks guys- it is as I feared. So keen on being able to see the fruits of my labour + I owe a lot of people their parts back! I'll look for that lifter/ pushrod combo. Any recommendations for where to source these parts from? Locally we have A bursons, sca, Scott's, repco and an engine builder. -
Hey people of Rollaclub, I am in urgent need of some info/ personal experience when it comes to combining a 5k block with a 4k head. At the moment I'm in the middle of my 5k conversion which has involved rebuilding a 5k bottom end, pulling the 4k and 4 speed and then transferring all of my 4k ancillaries and head to the 5k. I didnt have the 5k head so i did loads of research and ended up swapping to 5k shallow dish pistons so that i could just run my 4k head. However- i wanted to stay hydro and still had the lifters, pushrods and rocker assembly to do so, but the pushrods are too short! They were meant for the shallower 5k D-dish piston head :hammer: SO, at the moment the combo is assembled with 4k solid lifters, pushrods and rocker gear. My question is whether or not you can run this combo (i have a reground hydro cam). The only thing that seems out of place is the slightly smaller diameter of the 4k solid lifters (they are semi loose). Will this work??? Other than this the 5k is ready to go in! THis is my first engine build/ conversion and i need my car for work on monday so any help is appreciated! URGENT Thanks, Ro
PM'd
180Sx Struts/Brakes Into Ke55.
Yeah cool, thanks for the info/ advice. Unfortunately i havent yet found anyone who has done this conversion to a ke55, and have never really been a fan of pioneering this kind of stuff. Maybe ill offer what i have up for cheap sale to a ke70 owner and suss out other alternatives. Really, id just be doing it for the bigger brakes, and because i got stuff cheap! Thanks, Ro -
Still after any help for this. Mainly which strut tops can i use? -
Ooo can't wait to see this supercharged! You have such a wide range of skills, and good taste! Keep going!
I'd love a Jap style one too! PM me with bank details? Thanks!
