4k trike
    62
Everything posted by 4k trike
  1. cheers trev bit slow on reply computer done a left hand spigot bearing harddrive adapter
    Read more
  2. cheers ill try that
  3. there are no stupid questions yep its hooked up its only conected to the rear inlet manifold pipe (# 4 cyl) when valves are shut and cylinder is combusting air will build up pressure in manifold runner pipe then valve opens and pressure drops would this affect the psi ? ive got a feeling that the 2nd gasket i blew was because i ran over a stick and boost/vac come of (maybe) i dident get any other paperwork with msd unit other than the above download and a 1 page addendum for the btm model steps 12&3 mounting step 4 conect 1/8 tube to msd spigot and route to a port on intake manifold cheers
  4. exelent job what sort of power u expecting to get?
  5. cheers jono
  6. i can't find link atm maybe google msd6btm hope this helps
  7. thanks taz all help apreciated
  8. has anyone had anything to do with msd 6 btm ignitions I'm having trouble with my blown 4k blowing head gaskets thanks
  9. msd has a dial witch provides variable timing retard in relation to the amount of boost occering ranges from 0deg to 3 deg per pound of boost eg knob at 2deg times max boost 6 pounds boost = 12 deg ill try to scan a copy or i got a manual via msd wedsite
  10. re dizzy its either vac or adv not sure witch one it has 2 vac tank/hoses coming from it (2stage retard?????)
  11. thanks guys $55 grapite ? gasket from autobarn couldent get genuine one in time will get one next time timing was about 22 deg at idle what is base timing ? the vacum retard/advance hoses on the dizzyare blocked i think the msd unit (msd 6 btm) should retard /advance the spark itself (don't quote me) the msd has a 1/8 vacum hose from it to the manifold at the monemt ive got vac hose on the rear inlet pipeof the manifold (its not providing vacum regular) i think i should have it on main blower pipe? should i get the dizzy locked some1 told me this idont understand it much apreciate it :)
  12. finally got some pics up just blown the 3rd head gasket having trouble with the timing it seems to be advancing 8-10deg over 3000 rpm i think the msd unit should retard it it mite be time to find an expert ($$$ permiting)
  13. got new ed gasket fitted extractors are on tuned up going great responsive on the throttle sounds sweet pics/vid soon
  14. thanks guys the gasket had the closed holes pushed open duno if that means anything ill try to get a good monotorque gasket today
  15. hope gasket was faulty mite have had air lock in it i did notice gasket dident have all holes for water to flow through opened up got any sugestions? ran enjin for 1 hour nateraly asperated
  16. finally got it all back together charger msd eletric diz are all on gave it a run in the paddock goes great bit slow of the line hope its the timing or flat spot in carby but ive done a head gasket i think hope like hell its not a cracked head go to town tomorrow for extractors,head gasket and a few small fittings gee i hope i havent done a head on the up side the msd unit is good highly recomended f@$k i got a zap from it the motor sounds crisp can't wait for sunday 16 may not long to go now
  17. thanks all ordered msd and starter today not long to go now
  18. thanks for that guys appreciate it
  19. trying to order a 4k starter supplier can only find 3k 1200cc are they they the same thing?
  20. finally got it all assembled ready to give rebuilt motor a run in havent got charger on at moment plan on giving motor1-2 hours run in nateraly asperated to help bed rings etc now i just need msd 6btm (tomorrow i hope) extractors startermotor plugs and leads :bash:
  21. first one mentioned has multi spark (inbuilt spark control) and rev limiter second one is just timing retard no spark unit so for extra 2-300 i can get spark unit and timing retard in one unit cheers for the advice
  22. thank taz get one for 700 not cheap but good spark =performance i hope I'm running out of time so it an easy option
  23. getting it back together slowy having issues with retarding the timing gunna have to buy a msd 6btm i think hopefuly it will sort out my problems more soon
  24. 4k trike
    Msd-7
    does any one know if a msd 7al unit has a built in retarder
