4k trike
    62
About 4k trike
  • Birthday 09/26/1978
  • Location
    dergholm vic
4k trike's Achievements
  1. cheers trev bit slow on reply computer done a left hand spigot bearing harddrive adapter
    Read more
  2. cheers ill try that
  3. there are no stupid questions yep its hooked up its only conected to the rear inlet manifold pipe (# 4 cyl) when valves are shut and cylinder is combusting air will build up pressure in manifold runner pipe then valve opens and pressure drops would this affect the psi ? ive got a feeling that the 2nd gasket i blew was because i ran over a stick and boost/vac come of (maybe) i dident get any other paperwork with msd unit other than the above download and a 1 page addendum for the btm model steps 12&3 mounting step 4 conect 1/8 tube to msd spigot and route to a port on intake manifold cheers
  4. exelent job what sort of power u expecting to get?
  5. cheers jono
  6. i can't find link atm maybe google msd6btm hope this helps
  7. thanks taz all help apreciated
  8. has anyone had anything to do with msd 6 btm ignitions I'm having trouble with my blown 4k blowing head gaskets thanks
  9. msd has a dial witch provides variable timing retard in relation to the amount of boost occering ranges from 0deg to 3 deg per pound of boost eg knob at 2deg times max boost 6 pounds boost = 12 deg ill try to scan a copy or i got a manual via msd wedsite
  10. re dizzy its either vac or adv not sure witch one it has 2 vac tank/hoses coming from it (2stage retard?????)
  11. thanks guys $55 grapite ? gasket from autobarn couldent get genuine one in time will get one next time timing was about 22 deg at idle what is base timing ? the vacum retard/advance hoses on the dizzyare blocked i think the msd unit (msd 6 btm) should retard /advance the spark itself (don't quote me) the msd has a 1/8 vacum hose from it to the manifold at the monemt ive got vac hose on the rear inlet pipeof the manifold (its not providing vacum regular) i think i should have it on main blower pipe? should i get the dizzy locked some1 told me this idont understand it much apreciate it :)
  12. finally got some pics up just blown the 3rd head gasket having trouble with the timing it seems to be advancing 8-10deg over 3000 rpm i think the msd unit should retard it it mite be time to find an expert ($$$ permiting)
  13. got new ed gasket fitted extractors are on tuned up going great responsive on the throttle sounds sweet pics/vid soon
