221 -
Everything posted by ae95- wagon kid
All i can say is Eastern European chicks are Winning!!!! oh lawd
the food is better, the women are hotter, the cars are faster and the architecture, culture and way of life is better in my opinion, i thought we were well off until i did that trip also they have alot more freedom to do whatever they want to there cars without being defected for being to low by 3 mm
i Have not been on rollaclub for the last three months due to being overseas i went to England germany austria czech republic sweden spain the netherlands France Norway Italy Greece Egypt and Finally Turkey it was a big massive expensive trip but also life changing. Ive missed the forums but I'm back now
Have a search on this forum there, you could get a engine loom etc to fit easy. many have done this conversion, just swap the whole motor why have a weaker bottom end when you can just use the 4age one or for a bit of uniqueness why not plumb up a turbo system and run it through a 32/36 weber :) run in on 6-7 psi every day and you could build it on the cheap
My mate and i Had just finished building a stroked 49cc engine to go on his project bike. So we tried to start the shiny fresh engine with a small amount of start ya bastard into the carby After a few pulls it still wouldn't start so we put the can down and went in for drinks and we hear the engine cranking over so we come back to the garage to find my other mate with a can of heavy duty primer in his hand SPRAYING it into the carby he had put half a can in by the time we stopped him.
I'Ve Got This Crazy Idea For A Daily
ae95- wagon kid replied to benhachi's topic in Automotive Discussion
You can get a kit that coverts your bike to run a 40cc honda motor or you can also get a kit to run a 49cc engine i got a 32cc whipper snipper motor and welded up a frame when i was younger and rode that to primary school got the motor for free, metal for free, brought some rods made up a throttle cable of a rubbish bike and rode that to school at 40-50 kph easy 21 cents to fill, lasted me till the weekend i used a bike peg so i could use a friction drive system ie pedal to start brake and it cuts out simple affective and easy Just my 2 cents ;) -
time to pull your air con apart and have a good look, your best bet. if after that you can't find it take it in to get looked at, check under the car if you want to see if your cat is leaking but i highly doubt it would come through just your air con possibly your battery is leaking acid into the bay and getting picked up by the intake of the air con????? could be that vinegar acidic smell check that too hope you can solve it mate would love to find out what it could be Harry
plus one for cat probably it pricks have been known to put sardines in places such as those on a hot summer morning for you to drive home that following afternoon :bash: when they re-gassed your aircon something mights have gone wrong hope this helps
pretty worked meaning what?? fuel+air= power if you have a stock 5k carb it will never be as performance orientated as twin webers or a single 32/36 If your motor is worked this may be the one thing lacking to give it that extra oomph that your motor needs
trying to track down a member on toyota nation and twincam.org who goes by the name of Cuzman he owns a white ae95 with a 20v if anybody has a phone number or an email address that would be fantastic thanks in advance Harry
would be good for a cheep track day slider apart from that it makes the car handle shit if its for street just go with the usual carby upgrade extractors and a tighe cam save up and get a lsd if you can find one to fit and thirded WHY???
got much more support mate, i recon it would pay for itself pretty quick mate
I live in the mitcham area, i recon i might have seen them on a red ke70 with no back bumper sorry for being vague hope it helps
Having to choose whether to put 15k towards building a fu#king sweet as ae95 and a hilux or going to europe for 3 months before uni i might return with 3k in my pocket or debt who knows FML :(
If anybody spots any ae95 wagons not TERCELS!!! let me know as i need a few bits and pieces thanks in advance Harry
me and my mate would be very keen mate. got about 6 cars to do :)
People who F#ck you around 2 minutes before cloesing time, after coming back and trying to return an item that they had been told would not suit their purpose. with no reciept and being incredibly rude = get the F@CK OUT OF THE SHOP YOU OLD #unt
What Makes You Happy Thread
ae95- wagon kid replied to t18drifts's topic in Rollaclub Social (Off-Topic)
Watching F1 nuff said :) -
either find a 2nd gen 4afe ecu or just plug in the 1st gen one it should work the same are you sure your head is gone, water dripping out of the exhaust shows a build up of condensation if it had been sitting for a while or it had been cold the night before it could have occured. check your oil if its milky or has air bubbles in it. its a 4afe they are pretty indestructible even the head gaskets have another check before you pull it apart
Good one evan ;) mate anything can be done with time and money. if you can do it yourself and have the tools then go for it there would be a few posts on here abou similar or the same swap. ie can i put a v6 into a ke70 or can i put a commodore motor in a ke30 with a welded diff anyhow think about what you want it to be used for and how much you have to spend. Harry
found out today, a leed had split, and wasnt working :( fml
I havent had time to check the timing, as i don't have a timing light to do it properly i recon its the sensor will check it out when i don't have work thanks fellas.
Just a heads up there are a set of performance 15x7's bathurst globe look alikes with not tyres plus there is a ke70 that just arrived with a 4k ( i think) with a asian carb with a make do sock on it and manifold don't know if it is a stock carb don't know much about k series these are at the lonsdale u - pull it
Gday fellow rolla club members. my family just brought a 323 astina 1992 it is idling really low and doesnt like pulling off and seems to starve of petrol and then comes to life after around 2000 rpm i have checked the transmition and its fine. i am convinced it is to do with either the injectors, a sensor or the fuel pump. sorry for being so vague and ideas what it could be and what to check thanks in advance Harry
