wagn
    348
    4
Everything posted by wagn
  1. valve bounce is your rev limiter!
  2. Small update got my kp61 trd 2way lsd diff center so i have to see if it will fit Also got some new slotted rotors and qfm hpx pads Qtr panel just needs to be fitted so i can paint,got some new window rubbers too pick em up saturday.
  3. I just got a set of rda slotted rotors for my jap 1973 ke20 the rotors have the same step etc as the rotor on the right in the first pic they fitted up perfect with new qfm pads and my calipers are akebono or whatever i just ordered ke20 stuff no jap or adm specific parts
  4. pvc over gocart wheels then pump em up hard no real specs on the rear end just a bent pipe with gokart stub axel things welded into the end ill get some pics tonight
  5. you bet it does! that one isnt mine but mine is the same just with a dropped rear axel brings it about 2 inches lower to the ground hopefully vids this friday night
  6. did you go up thru corkscrew we were up there on huffy sliders and saw a couple of fwders and a rolla couldn't really see well it was too dark
  7. I 100% agree with 7shades i'll be running a nardi on my 20
  8. work on the car,film & make videos of cars&bmx and ride bmx too spend way too much time on the computer i hang with the gf aswell
  9. http://www.hachiroku.com.au/blog/?p=4754 Who's going to this? I'll be making sure my 20 is ready should be fun with a whole bunch of toyotas on the track
  10. your in sa go down and see Jay at buddyparts he has a beams in a ke70
  11. Was mentioned in Evan G's build thread http://www.rollaclub.com/board/index.php?s...40319&st=30 and when i was looking up heat wrap on google
  12. took these at matsuri just after it got rolled
  13. Got my extractors yesterday wire wheeled them and ground back some of the welds near the bolt holes so the nuts can sit flat not sure weather to heat wrap them or not was reading it can make them crack easy?Anyone made a heat shield seems pretty tight.
  14. I'm going to run slotted rotors and qfm pads on my 20 i think it will be a good enough upgrade for a warm 4k
  15. No one had any experience with these shocks?
  16. Yeah there damn expensive i knew about the toda ones TRD apparently make/made one too I'm so tempted to waste stupid amounts of money on a k engine and this would be a perfect way to do it haha
  17. Where did you get the flywheel?
  18. Thanks for the tip mate but i want to put new shocks in as everything else suspension wise will be new
  19. As ke20 front inserts have very limited for options i just wanted to here peoples opinions on what is the best available.As far as i know you can get them from pedders,monroe,gabriel and ac delco.What would be the stiffer of the bunch? are there any others that i haven't listed etc?
  20. Update time! I got a rear half of a ke20 off lukeae71 for the donor quarter panel almost finished unstitching it then the car will go to have it put on hopefully in 2 weeks then it will be painting time. Also got a 45 weber and manifold off jono1986 have a rebuild kit and inspection cap and wing nut on the way to give it a rebuild starting to clean up all the casting marks on the inside of the manifold. The throats were pretty dirty gave them a quick clean up but will clean it properly when i take it apart i also have a set of extractors on the way too.This will all be going onto another 4k that i will be rebuilding putting in a cam and some headwork.
  21. kp61 diff centre with trd 2 way $200
  22. 1x corona wagon 1x ke55 2x ke20
  23. Agreed
