348 -
4
Everything posted by wagn
What Tally said + TE27 Cusco camber tops (or stock KE20 tops)+ AE86 hubs and brakes and possibly brake lines? then you should be good to go
do you even need more camber than you can get with your camber tops?
ill be keen too
thanks luke i was going to try find some stockies if i could borrow them for the day when it comes time to take it thru that would be sweet! Only a few more things to do now and it should be good to pass inspection just need to work out why my horn isnt working and a bit of welding
got my new dash pad fitted today
there was last night it wasn't a complete kit it had trd mounts,modified sump and modified oil pump
there is upright kit on yahoo auctions at the moment :yes:
i could be keen on a nice set of tuned length extractors
don't paint strip
4 dr with flares
here's a photoshopped pic it will be a bout 30mm higher than this when I'm done
Cheers Josh no way this is getting white walls unless i pick up some 12's and original hubcaps i'm not a fan of walls with mags will get a sensible amount of low the day it clears rego :yes: I have a nice new cusco strut bar on the way aswell,a nice xmas present from the gf
camber tops added to coil overs and new 175 60 R13 federal formoza fd1's
Got a few more to come
I have a few pics of the cruse i will post up tonight
not much been happening to this thing got my dash pad last week :y: cheers raven. Saving to go to japan again so there wont be much happening the the car till after may next year
With jellybean wheels and real loud? if so it lives round the corner from me
Few things turned up today :) Replacement clamp for the c clip on the clutch cable Cusco camber tops Lite flywheel needs a clean/machining.Just under 4kg going by shitty scales
yeah probably going some 175 60 falkens and lower once it clears rego,No there not luke's old wheels i bought these over from japan
got it out the shed for first time in 8-9 months today it's nice to stand back and look at it instead of squeezed in the shed needs lower profile tyres
Coil overs are done just waiting on my camber tops
i have herd nothing but bad things about extreme clutches also
thermo spinning the right way?
