rolla-king
    26
About rolla-king
  • Birthday 07/27/1992
  • Location
    Blue mountains NSW
Recent Profile Visitors
5462260 profile views
rolla-king's Achievements
  1. thanks mate. It's mongoose sound deadening. I think it was $120 a box and you get 9 sheets in a box. It's just a pain to install, especially inside the doors. But it works well with road noise. Yeah the turbo is going to sit pretty close to the bonnet so I'm going to need to do something to protect it.
  2. A change of direction has happened, I wasn't happy with the power that the 5k was putting out and I stumbled across a 4k turbo fuel injected set up on eBay that sleepercorty was selling. So I drove up to QLD to grab that, took the 5k out and put the 4k in. I have since replaced all the fuel lines in copper as I'm a plumber and that was the easiest way to go as they were ʞ©$ɟed anyway, installed a surge tank with the two pumps and a heavy duty fuel filter which cost a overrated as its going to be running e85 and not all pumps and filters can handle that fuel. (not all together in photo because I took the tank out to weld new barbs in it for the surge tank) I grabbed a B&M shifter for the trimatic tranny which should make slamming through gears fun. I have a mate who works for a company who build race cars and he is making a new custom intake manifold and exhaust manifold to make the the flow a little better and to make some more power. The motor had a blown head so I got it slightly skimmed, new copper cometic gasket and ARP head studs as the originals were STRETCHED. I have also fitted a turbosmart plumb back BOV and a turbosmart dual stage boost controller. One of the things I'm not 100% sure on is what oil to be running through the motor and turbo, anyone have any suggestions? It's obviously more effort then a lot of people would go to with a 4k but its going to be interesting to see what sort of power it makes, sleepercorty said he made 160rwhp on 20psi so I'm hoping to make more then that. Please leave your feedback as I'm interested to see what you guys think
  3. thanks for your help mate. It's just an electric dizzy which then runs to the ecu. I'll have to check the timing. Do you happen to have a link to those bolts in the for sale section? I can't find it.
  4. Hey guys I'm leigh,I'm attempting to re-build a 4k turbo injected motor. The motor had standard head bolts in it but they stretched under boost and blew the head gasket. I have been searching for a metal head gasket as the standard seems to blow at 10psi. Does anybody know where I find a metal head gasket? Also has anybody had any luck getting ARP head bolts/studs? They don't stock a kit but ive heard of people using arp bolts in 4ks. Any help would be great. Cheers Leigh
  5. hey all. A lot has happened to the rolla since the last post. I've had the twin carbies taken off and rebuilt, has made a huge difference to the amount of fuel its using. It still leaves black marks everywhere i park it though. The rear brakes were pissing out into the drums so i had them redone, which added more pressure into the brake line every time I hit the brakes (as it wasnt leaking out anymore) which in turn blew the master cylinder. Which then ate most of the paint behind the brake booster. The car is up for a respray, the first paint job was ok but who ever did it didn't get all the rust. I got a 2 1/4" exhaust system in. Was pretty loud so I ended putting a longer hotdog in to take off some of the edge. To kill some of the road noise i stripped the interior and boot and put sound deadening in everywhere I could fit it. it has made a massive difference. The car is pretty reliable now, only problem is the amount of fuel and oil it uses at 110kms. it revs at about 3500rpm in fifth and you can definitely smell the oil. Not entirely sure what I'm going to do about that but ill sort something. Future plans are to get the suspension stiffened and possibly lowered. the front springs were cut so they are pretty much useless and the back is stock from back in the day so it'll be getting an extra leaf. Would like to get a nice set of 5 spoke chrome rims for it. maybe 15"-16". Also considering getting a gilmer drive for it. Its pretty much just the cost thats the issue. Thats about it for now. ill add some pictures too. If you have any advice or comments please let me know.
  6. 5k is back in the car but not running yet. looks good though.
  7. Ill probably keep those rims on it for now until i find something better. Those 20s won't be going on it.
  8. A few things have happened since the last update. I have the pulled the 5k back out to tidy up the engine bay. While the engine was out i cleaned it all up and painted it mat black. I painted the x-member, brake lines, fuel lines and steering rack gloss black. The engine bay is going to be all orange with black 5k with random chrome/stainless and red bits. The gauges have been fitted into the dash along with the push start and the entire dash has been painted mat black.
  9. No i am definetly not using those chromies, i will be selling them with the blue rolls when i sell it. Heres an update picture
  10. Original door trim from donor car. Engine finally going in. it was hard doing it on a dirt road. Engine in. Donor car. Painted brakes. before and after.
  11. hey all I first bought my ke55 off ebay, it had: -a new blood orange paint job -2" lowering blocks -no engine -no locks -no side windows -half a loom The plan was to have a nice ke55 daily driver that was nice to look at and reliable. I decided to keep the stock interior just tidy it up a little with reapolstering the seats in black, new black carpet, new black headliner. I have bought 6 new auto meter guages which i am making a new gauge cluster out of. The gauges include: -Speedo -Tahco -Water Temp -Fuel Level -Oil press -Volts I am also taking out the ignition and replacing it with a switch for accessories, a switch for reds and a push start button. I am putting in an alpine flip out screen above the shifter, two alpine SR speekers under the dash and two under the pastel shelf, a kenwood amp under each of the front seats and two kenwood subs fibreglassed into the boot. Also fitting an alarm and power windows. I have hidden all the wiring in the engine bay to make it look alot cleaner and attaching it to a drycell battery. I decided to keep the 5k engine with a 5 speed with twin carbies and extractors with a 2.5" exhaust with dump pipe. i pulled off the brakes to paint them cherry red.
  12. Hey everyone, so a few things have changed since the last post: -The engine is in (not fun on a dirt road) -I decided to change the interior colour from chalk to black (unfortunately after i make up the chalk interior) -I painted the grill -Got a new radiator
  13. Another update on the corolla. Since last update i have bought an engine!!! (thanks rob) Its a twin carby 5K, it was on rollaclub so I'm sure most of you have seen it. I have also found myself a steering wheel and a dash pad. I have started to cut out my door trims and back shelf, they are a light cream colour. Please give me your feed back and comments.
