Hey Guys...
I could sit here for the next 48 hours talking about how good these cars are and how much funy people are going to have driving them, or even being a passenger in them, but I will let you work that out for yourself. As far as rules for the ZZE Sportivo's, I have but 2.
1 - Have fun. THis may not be the most lethal car on the road, but you will have bucket loads of fun in it....so enjoy it...
2 - DO NOT FIT A CANNON EXHAUST!!!! (I'll explain why later....)
So as far as mods, there are quite a few you can do, some bolt on at home type stuff, some a little more complexed, howevere most for this model are relatively affordable....
I'll start from the ground up...
WHEELS - There are a myriad of wheels available for it. The standard wheels aren't too bad, however the majoy problem with them is the sizing of the rubber. Holding 195/65/16 stock, there are only like 2 or 3 manufacturer's that make this size, and starting at $240 each, it's not in your best interest to burn through them at too quick a pace. Most of the guys I know have up'd to 17's or 18's. I prefer 17x7's as the rubber is still more affordable and the size fits well. There are a lot of guys that have gon 18's and had scrubbing issues on the inners. SOme have been OK, but I can't recall anyone scrubbing 17's on them...and especially in QLD with the "not going any larger than 2" from base model" law thing, your safe on 17's. As far as rubber, well everyone has their opinions, so I can only speak from experience. I am using Fulda Exelero 205/45/17's and they are fantastic. The tyre itself has a rim protector built onto it to assist with not getting ugtter rash on the rims if you park too close to the kerb, and have been great wearing, comfortable, fairly quiet and nice grippy tyres. As far as I am aware, they are one of the few tyres areound with AAA rating.
SUSPENSION - Depending on your budget here, you can go kinda crazy. Myself, I spent $200 on a set of King Springs (Lows) which lowered me 30mm and still leaving me just over the old fashioned 100mm legal clearance height. I also spent $150 on a Whiteline Strut Brace on the front. It isn't a slot car, but the improvements to the ride and handling are significantly increased, and the comfortability factor is also good. If your budget allows more, then for a few hundred more, you can also add a rear strut brace. Whiteline have been popular with the portivo guys, and pretty good, although some opt for a few $$$ extra and go either for the TRD at around $450 or so each. When it comes to springs and struts, as I said, I have Low Kings on stock struts, no problems whatsoever. SHould you opt for the SuperLows, then you will need struts too, as the stock struts will last you about 1000km's on SuperLows. I have been using the Lows with stock struts for about 50,000kms and have not had any problems at all. Good Old Fashioned Koni Adjustables have been proven very reliable on a Corolla. If your budget allows, then for between $1000 - $2500 depending on brand, supplier and type, coilovers are going to be advantagous and will never be a bad mod to make. The Cusco D2's are very popular with Sportivo owners that I know. Agaon though, price is usually the limiter here for most people.
INTAKE - I could give you probably 3 options that I would suggest. ONE: Leave it stock. Yes, performance is improved with a mod here, but intake is not an essential mod on a Sportivo. TWO: K&N do a panel filter for the ZZE which has been good. Although no proven gains, certainly the difference can be felt slightly if you are familiar with the car. THREE: My favourite, Cold Air Intake. Most guys I know went for a TRD. Yo ucan usually reaslistically grab one new for around $450 - $500 depending on exchange rates. Second hand, you could get one for between $300 - $400. Other intakes guys use are CES or the AEM. The CES one is made here in Brisbane and modelled off the TRD one has has proven gains. I don't know too many with AEM to speak of it, however the couple of guys I have spoken to with them have no complaints.
HEADERS - TRD ones are the preferred amongst a stack of the guys I know, however pricey. Last I heard, up around $1100. CES do a replacement set of HPC coted port matched ones for around $700 or so I think. Not a mod that is essential to the car, but certainly will give some small gains in the right areas. The difference we found between 2 Sportivo's with identical mods, excpet one had headers, was all down low (0-2500rpm)...
EXHAUST - A very big issue of contention amongst any car modder. My number one rule with the Sportivo exhaust, as I mentione earlier, is not to put a Cannon on it. I have never seen a cannon on a Sportivo that did anything other than make the car sound like a wet fart. They have proven time and time again to actually restrict the car's power output. My advice, don't bother. Other bolt on style exhaust have also proven to fail in the performance section of a Sportivo, such as the X-Force, 5-Zigen and other bolt on options. I take it by the number plate, your in Brisbane. This helps if you want an exhaust, as the one I would highly recommend is built in Brisbane, and has actually had Sportivo owners across the country either drive here to buy them, or bought them and had them shipped home to be fitted locally. CES Racing Systems have built a Cat Back Stainless 2.5" system for the Sportivo that has proven gains. (I will get into the power side of things later). At around $960 fitted for the version with Mild Steel flanges or an extra $80 or something for full Stainless Steel flanges, again, I can not speak highly enough of it. Just don't fit a cannon...
ENGINE - How big's your budget? I know guys that have left them stock, and I know people that have Turbo's them. Do not do anything to the engine unless you realistically have time and ooodles of money. I'm not talking a couple of grand. I am suggesting that unless you are in a financial position to be able to order the parts, fit them and pay the bills and probably not need to ask the price, don't start a turbo project on this. I will get onto power down the track, but please just be a typical newbie with a Sportivo and rant about how your gonna turbo it cause your mate with his Skyline can help.... not gonna happen...and no, the bolt on TRD SUpercharger ain't gonna happen either... My advice, is leave the engine alone unless you can afford it.
ECU - Again, not an essential mod, however I know a couple of guys that have gone with the Apexi PowerFC at about $3000 fitted and tuned. The only issue with these is that these are designed for the 2ZZ engine, yes, however they were designed for the Celica 2ZZ which actually has 2 ECU's so the wiring is all wrong for the Corolla, unless you know the right guy that actually knows what he is doing. Again, don't do the "I know a guy with a Skyline" line cause I have seen guys screw their cars up with these things until they got them running properly...very costly... One guy had to do around 50 dyno runs to get his tuned properly.....and you have an idea at Dyno prices, yeah???? The Apexi RSM is also a good little add on if you like. Not sure of the price, but $600 - $700 rings a bell, although I could be wrong. It will give you speed, RPM, 0-400m, 0-100km/h etc...
GEARBOX - Leave it alone....
BRAKES - Stock they are fine. SOme guys have used the DBA stuff.... I know one bloke looking into R34 GT-R discs, but he's running 19psi TUrbo and has 230kw ATW.
HEADLIGHTS - I have a personal objection to people using thos 'Whitelook' and 'Blue' lights. They are horrible, yuck and make the car look cheap. Depending on your budget, about $700 will get you into some decent HID's. If moeny is tighter, then about $90 a set, will get you Philips Crystal Vision bulbs. Other than that, I wouldn't bother. About $50 will get you some aftermarker eyelids. ABout $130 will get you TMC ones. I'd recommend the TMC one's as you will get a better color match.
STEREO - How big's your budget? Double DIN headunit is easy to replace. I think they are 5" and 1" in the front doors and 6" in the rear doors. Mine are still stock.
OTHER MODS - You already have the Sportivo Grill and Rear Skirt. The only other thing's I'd look into would be purely cosmetic, and that is for $6.00, you can use silicone sleeves to change the LED's in your console to make them red to match the dash cluster.
POWER - This is where all the fun is. Stock, these babies do the old quoted 141kW engine rating. At the wheels is where you need it though, and the challenge, as with any car mod project, is to lose as little of that power as possible. Stock, you should do between 103 - 110kW ATW. Mine is a freak, and I have 2 readouts, 12 months apart at 112.5 and 111kW ATW respectivley. The TRD Cold Air Intake has proven gains on these cars at around 4kW ATW. The CES Exhaust I was talking about proved between 6-9kW ATW. Most guys I know have these mods are between 115 - 119kW ATW. I have the TRD CAI and the CES, and my last Dyno was 121.1kW ATW. Like I said, it's a freak. I also mentioned my friend with the Turbo on his, yes, the budget is probably that of the GDP of a small country, however for a little 4-pot with 230kW ATW, was well worth it...
This is what I have done to my car...
CES 2.25" Stainless Cat Back Exhaust
TRD Cold Air Intake
TRD Pod Filter
White Line Front Strut Brace
King 'Lows' Springs
17" Zeptor 5-spoke Chrome Rims
Ming Titanium Window Tint
TMC Eyelids
TMC Floor Mats
TMC Dash Mat
TMC Carbon Fibre Look Rear Number Plate Trim
Black 'Sportivo' Sideskirt Badging
Black 'Sportivo' Rear Toyota Logo Badge
Red LED's replaced in stock Head Unit
Mate, I hope this helps. If you need any more advice, or want to be pointed in the right direction, let me know. I have spent 4 years playing with SPortivo's and could show you a list of 100 guys I know with them that have done various things to them to improve them.
If you want to have alook at mine, let me know. I'm in Brissy, so I can meet up with you somewhere and go through some stuff with you...
CHeers
Aaron
