Kebin
Region Leader[RL]
    610
    3
Everything posted by Kebin
  1. it all depends on how your car has been wired. is there a circuit opening relay in the car? if not, a fuel pump relay?
  2. Fuel relay = Circuit opening Relay = the relay you pictured. The link c/o relay wiring description is wrong it should read: White/Black - Wires to body earth - Wire to closest earth point. White/Red - Wires to EFI Relay - +12v Ignition Switched power (Run through a suitably sized fuse, 10A is usually fine, but depends on your fuel pump). Green - Wires to engine run signal - "FC" pin on 4AGE ECU. Or if you are running an AFM engine, this wire should connect to the AFM. Black - Wires to to STA - Starter/ECU Start Signal. Blue/Black - Wire to fuel pump positive - Gives power to your fuel pump.
  3. Anyone notice that the 26th is a Friday? :no2:
  4. Meet up is actually at Engadine Mcdonalds.. there is no maccas at waterfall. http://maps.google.com.au/maps/place?cid=1...8825,151.010685 Woohoo Sea Cliff Bridge FTW! http://www.theage.com.au/news/explore-aust...3555565762.html
  5. i recycle... i strip old wiring loom leftovers from peoples halfcuts etc. That way i can wire up conversions as per factory colours. Its cost effective as well as easy to diagnose.
  6. I'm liking your build! What front suspension setup are you running? Anymore pictures?
  7. OMG you wont!!!! Best thing ever! Quality wagons are the shit!!
  8. can't confirm but a safe bet would be the 4ac loom wont have any of the efi circuits in it.
  9. I like the idea of that
  10. did you modify the drag link yourself or get someone to do it?
  11. panel van is still same shape as wagon ;) just short of the panel van and the 4 door sedan to make the entire ke1x series
  12. i have never ever seen a 4 door wagon? only seen 4 door ke10 sedan
  13. I raise you..... every KE1x shape in my backyard :)
  14. wiring pics ;) n/a 2j cruiser ftw.
  15. Found some...... http://www.sarotors.org/forum/album/events...Tc3OWMyMzExOTAz http://www.sarotors.org/forum/album/events...GE2ZGNmNzFlMWRj http://www.sarotors.org/forum/album/events...DU0MjYzYmM5OTFj
  16. more pics of the convertible please :wink:
  17. taking delivery this w/e.. will get pics asap
  18. I'm interested in anything you can do for the front end of ke1x series. I can even give you a stripped out written off ke10 shell to toy with. :wink:
  19. bump like a forsale thread? :(
  20. 2 thumbs up for the ae95 lift kit ideas! waiting for the action shots! :) Needs a bullbar and spotties next!
  21. 4age or 4afe ae92? yes they fit but the vacuum idle up valve for a 4age rack will be on the rack itself whereas the 4afe is on the power steering pump. Use a 4age rack when doing 4ag* conversion to ae95.
  22. Good to see a radrollaz car being taken to the next level! Top stuff! Subscribing to this thread!
  23. hahaha
  24. rippa of a cruise! great variety of cars. Awesome weather. i love aircon :P
