greendog
    26
Everything posted by greendog
  1. They have common problems in the indicator stalk. There is factory bend in the wiring that will end up shorting out, not sure if that's your problem but worth looking at.
  2. so i took my car wsid yesterday it was my first time ever drag racing,i had a ball,i had to take easy on the car as its my daily and i only been running for 3 or 4 weeks after completing a low budget 4age conversion. my target was to do a 15.9 ended up with a best of 15.50:) i know it will go quicker after a few tweaks. ae71 (full interior) ae82 big port (unknown kms bit smokey and used.) standard cams ,4k electronic dizzy twin 40mm dellortos stock 4ac clutch and how do make the pic a thumbnail or smaller?
  3. nice work! spewing my computers not able read pdf atm :(
  4. runs good doug for early stages,bogging a bit like mine did,bigports makes it hard to tune that out.
  5. don't know how to embed the video heres a link short vid at idle. http://www.youtube.com/watch?v=m8HSl9Rfz3k&list=UUceULHR-G-163RVx7gns9sw&index=1&feature=plcp basic rundown: standard bluetop unknown kms 2 40mm dellorto dhla f 32mm chokes malpassi fpr redline manifold trd? 4-2-1 extractors modified electronic 4k dizzy ae92 12v coil sv21 ignition leads
  6. got my engine running now doughboy cheers for the dizzy works sweet.actaully goes alot harder than i was expecting.il post a pic of my setup up if u want.
  7. yeah i have no idea how to hot wire a car unfortunetly , googling more on how now..ta
  8. i just tried to start my ke35 i wrecked,it wont crank,its making relay noises at the relay under the dash. ive removed the instrument cluster,and it started fine before i removed it. does it need to be mounted to start? i really didnt think it would have been necessary for it start. if it is can i bridge the plug to start it.doing my head in here
  9. if you want something fat & lightweight,i can get 3 piece rims custom made to any size for around 1200,aus/US made.
  10. quality 510 mate,ha don't throw the L16 out. the fastest 510 on the track at the last datnats was l18 powered:]
  11. mikey_m you want to sell me your motor?seriously keen. was this out of the jesus rally car?you have a pm
  12. hey people i need to get a roadworthy tomoz,so need a to get a horn going. i was going to just take a stock wheel off my ke35 and fit it to my ae71. I'm thinking it will fit,but its pissing down outside and can't be bothered to go try in the rain. can anyone shed some light? i did found a thread saying all kes use the same boss. cheers nick
  13. ha inlet is like .10 cold think i found the problem
  14. just been having some dramas with our rolla, maybe someone has some input for me...number 1 cylinder isnt firing all the time, weird but seems ok when cold.lead seems good, plug is nice colour not wet and fouled,which is what i was expecting. everything seems kinda ok.so just did a compression test on no 1 its telling me 150, pretty good to me ? so now I'm going to check my clearences, but could this be bent rod maybe or would i be able to hear that. will thicker oil bump the compression up a little, oil is old.
  15. well I'm just about to get my 1200 ute back on the road so I'm selling my y as i don't really need anymore. I'm the 3rd owner, was owned by an old lady for about 25 years and was garaged at that time.. NO REGO! original a12 with 4speed not sure exact kms 110000 or 210000. reset rear springs cut front 310 control arm and ball joints carby was rebuilt bout 18 months ago drives exeptional new sony unit with 4 4inch speakers last owner tinted the windows looks only a few years old front unis are noisy(have spare but not any better really) minor damage in the rear rear gaurds have been cut, front rolled and have holes from fender mirrors minor rust car is pretty low and rides a bit harsh just the way i like it drivers seat has tears rest are pretty overrated will come with stardard steering wheel WHEELS PICTURED NOT INCLUDED $1900 car is located in wollongong 0401937684
  16. I'm near bulli dude, don't see many ke,s round here exept the bloke that owns the orange 4dr, he works in austy.
  17. i saw a cube yesterday and it looked awesome in the flesh i reckon.
  18. not super low but yeah its my missus car so low, but user friendly
  19. there is is special rubber wheel u mount to a drill that will buff that of in seconds cost bout 15bucks from automitive paint supplier
  20. in my few years on datsun1200 i can say that this was out of character for dattofrog,he has proved he is decent bloke with his apology for his comments.
  21. i think the chrome part is supposed to stay on the window,i found only the rubber comes off by small screw at the bottom of seal,.i think you could pry it off but will damage it more than likely. edit-sorry i thought u ment the chrome seal between windows
  22. hopefully have a spare housing this arvo, cheers but taz rx.but i have seen a couple thermostat housing bolts break(not toyota but) and ive broken one before its just annoying when a 10 min job turns into a two hour one,especially when the car has nothing really major wrong in the first place.if it reads the same after i change thermostat il compare with an aftermarket from my other car,thanks
  23. hey all, i have a 3k ke35 my temp guage is sitting bit over cold when warmed up,should it be at halfway?seems to be chewing a bit more fuel than it should?i have a new thermostat to put in but the housing bolts seem like they will break if craked so I'm trying not to change if i don't need to.what does yours operate at?ta-nick
  24. oh you my paint code was 8AE don't where the 8 comes from but problem solved thanks,
  25. yeah i don't know,ive seen similar all didgit codes,and i thought it was AE tg/?? tg paint ?? trim. don't want to take car down its ready to paint but may have to, thanks for help.
