Xany
    1592
Everything posted by Xany
  1. dude.....resize please....for the love of dial up people.. :jamie:
  2. looks like the dash may be out of a nissan 200sx......cut to fit of course. i love that front spolier bit how it joins up with the guards....looks good
  3. Firstly, WE are not here to give you detailed instructions on how to supercharge your 4K. However i will list the main points just so you can get a little idea of whats involved....then you should go and research BLOW THROUGH SUPERCHARGER SETUPS! 1.Pull 4K apart. Rebuild with better pistons, rings. Anything stronger than orginal parts and you're doing good.(you'll have to do this if you want your engine to last more than a year) 2. Find a Diff and gearbox setup that will be strong enough to take around 100 - 200hp....(not that you'll have more than 200hp) 3. Aquire Supercharger. (a toyota one is usually a good start). 4. Aquire Blow through carby or EFI setup 5. Make up custom brackets to attach to engine 6. Fit it up. Sound simple?......i don't think so. now go and do some research......we aint gunna do it for you.
  4. seems its been going around.....its a chain letter that prolly went round 2 years ago and somone has decided that they would like to have some fun and send it around again..... i've been had... :jamie:
  5. BIG WHOOPS!!! little hint people: don't believe everything your friends email you..... bwahahahahahaha
  6. i was wondering how you hooked up the ignition?.....i've thought about it a bit and could do it my way.....just wondering how you did it. also...do you use the stock fuel pump or an eletric one on the stand somewhere?
  7. bwahahahahaa.......hes still got his white blood cells to count....:D
  8. not too sure actually.....i might try and find out.
  9. don't be like that......all of us have done it at least once..... :D
  10. copied and pasted from an email i got from an astronomer friend of mine. NO ONE ALIVE TODAY WILL EVER SEE THIS AGAIN. The Red Planet (MARS) is about to be spectacular! This month and next, Earth is catching up with Mars in an encounter that will culminate in the closest approach between the two planets in recorded history. The next time Mars may come this close is in 2287. Due to the way Jupiter's gravity tugs on Mars and perturbs its orbit, astronomers can only be certain that Mars has not come this close to Earth in the last 5,000 years, but it may be as long as 60,000 years before it happens again. The encounter will culminate on August 27th when Mars comes to within 34,649,589 miles of Earth and will be (next to the moon) the brightest object in the night sky. It will attain a magnitude of -2.9 and will appear 25.11 arc seconds wide. By August 27, Mars will look as large as the full moon to the naked eye. Mars will be easy to spot. At the beginning of August it will rise in the east at 10 p.m. and reach its azimuth at about 3 a.m. by the end of August when the two planets are closest, Mars will rise at nightfall and reach its highest point in the sky at 12:30 a.m. That's pretty convenient to see something that no human being has seen in recorded history. So, mark your calendar at the beginning of August to see Mars grow progressively brighter and brighter throughout the month. SO COOL!!!!! More info Here
  11. AWESOME! that photo is now my wallpaper :D....thanks guys!
  12. ^^^^^^^^ BWAHAHAHAHAA We all know thats total bullshit....:D you'd get a video camera out and start filming =)
  13. i'm in the process of attaching a SC14 supercharger to my 5K however i'm doing it properly and getting the diff and gearbox sorted first so i wont break much when i do eventually get it on there....:D
  14. I did a little sketch of what i want mine to look like....i'm thinking of raising it off the ground about 60cm. Mainly for ease of working on the engine if there is problems with it. The clubs one would have to be made on the ground if it were to go into a tralier. I'm going to try and start on mine this weekend....i'll let you guys know how i go....btw my dads a carpenter =).....so he will probably have some good ideas up his sleeve too. PS. I have a running 5K (running 6 months ago when it was taken out) out the back that we can put straight onto the stand :D also....thinking of just welding some pipe onto the some standard engine pipes...then just adding a muffler i also have out the back.....so its not the full length of the exhaust system....probably go with: Exhaust manifold -> Engine pipes -> 1 foot of pipe -> muffler.
  15. a dimmer wire is the wire that controls the display on the front of the headunit....so you hook it to your dash lights, when it gets power the display on the front dims because you have your lights on. you may have mistaken this wire for something else.....not sure. its better for night driving, not having a big bright light shining in your face all the time is good.
  16. Does your headunit have a dimmer wire and if so where did you connect it too...that could also be your problem
  17. ^^^^^ That just cracked me up.....Bwahahahaha!!!! :D chris...i'm sorry we had to pike on you like that mate....i would have loved to come along but i thought twice because of jamie's party that night.... i need a fullsize picture for my wallpaper please =)
  18. You'll be pleased to know that Nick and I were having a conversation about this tonight....we've decided to make one....if not 2 (it looks fairly simple) from the spare parts in our sheds...:D With all the stuff i have laying around (gauges, coil packs, timber, metal and of course engines) i'm sure we could knock one up in no time. You've inspired me mate....you should be proud..... PS. One will be for the use of the club, and the other might be my own personal one. =)
  19. ^^^^^^ thanks jamie.....thats what i meant
  20. i also did the same thing :D.....we seem to have a trend going here.
  21. bwahahahaha......awesome.....i was thinking "yeah i may as well save the poor bugger"....then read the question lol i'd probably go with colour.....bit more dramatic :D
  22. hey guys......we need to make one of them for the club.....wouldnt be that hard. :D
  23. i totally agree ben..... why oh why.
  24. and they are stamped 5K
  25. we have one around the northisde here that has "Viper GTS" stickers down the sides and on the front and back windscreen...... evertime i see it i almost drive off the road in fits of laughter... :jamie: bloody tryhard badgers
