GJM85
    1821
    17
GJM85 last won the day on October 15 2015
GJM85 had the most liked content!
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    SE Qld
  • Real Name
    Gavin
Recent Profile Visitors
38365432 profile views
GJM85's Achievements
  • One Year In Rare
  • Week One Done Rare
  • One Month Later Rare
Recent Badges
40
  1. Ordered an update.
  2. Use ke2 inner bearing kp outer bearing.
  3. I use a denso 5k electronic dizzy with a Streetfire CDI (MSD's budget line) with a Bosch coil and 1.0 gapped plugs. Capacitive discharge, multi spark to 3000rpm and rev limiter. More energy that you'll every need.
  4. They make a DGV style one as well.
  5. A job done right and all that......
  6. Lowering the body to the road, lowers the centre of gravity which does increase the cornering ability but the tie rods(steering arms) and the lower control arms end up on funky upward angles where they were once almost square. This places load on the ball joints of these particular parts which they are not designed to sustain. The steering becomes heavy and the parts deteriorate rapidly. This increases sloppiness in the steering and bump steer. Roll centre adjusters (RCA's) are spacers used between the strut leg and the lower control arm to correct this problem. Next you have the issue of increased negative camber, where the top of the front wheels tend to lean inwards. Generally a positive trait on a track car and for the fan boys who love to chew through tyres, but the tread doesn't run squarely on the road, increasing tyre wear on the inside line and decreasing forward traction & braking capacity. Also increases bump steer. You use adjustable camber tops (strut tops) to counter this issue, although most wouldn't consider it one. Finally you have shock absorbers. Short stroke shocks are required to keep lowered spring trapped inside the strut itself. The standard shock absorbers upward travel is big enough it will allow the lowered spring to fly free of its upper and lower enclosure. These shocks are not generally of the shelf items and extensive part cross referencing is required to find the right shock and then you generally have to modify the strut to fit it. It's generally illegal to do for Provisional licence holders. It is definitely a lot more complicated than most people expect and the detriments out way the style points 9 times out 10 unless you do the job properly. Just do the 30mm springs in the front with 35mm RCA's (available through Techno Toy Tuning or others) with standard shocks and get a wheel alignment. Then use inch and a half blocks in the rear with Nolathane or Super Pro bushings. It will be cool.
  7. 50mm drop is significant and has negative effects on steering geometry without the appropriate counter measures. ie. RCA's and camber tops. It flogs the tie rods, pitman and idler arms, controls arm bushes and the front tyres. 30mm springs and 1&1/2" lowering blocks gives a good balance between stability & steering and doesn't attract as much unwanted attention, which is important for learner burners. And I'd still recommend the RCA's with that.
  8. I'm using a 32/36 DGV Weber on an early modified manifold. Never had it dyno'd but it's faster than a Mirage and a twin cam excel. Seat of my pants says its around 80-90hp.
  9. My head was done by Yatala Head Worx. 5k 30cc head. Intake is port matched and tapered with some bowl and comp chamber work. Exaust port is stock with the exception of bowl and short radius. Standard valves with Performance dual springs. 85lb seated. CC'd @ 10.6:1. Using 218/227@50 cam.
  10. It's likely that a lifter or 2 has collapsed and isn't functioning properly or lifter preload is incorrect. NB: if you convert to solid lifters you also need to change your camshaft to suit solid lifters.
  11. Does the engine run cleanly above idle? Like does it rev? I believe you got a blocked idle jet. Idle mixture at 2 turns out and idle speed at 1.5 turns in. If its runs when starved of air it could only be fuel starvation. Float level or idle circuit blockage.
  12. It's likely some cross plane, high rpm, low torque thingamajig suited to a momocycle. If it made 150rwhp in a 900kg car it'd be cool.
  13. I've heard ford use the same bell housing pattern across the 4 cylinder range for ever. Can't confirm but read that while looking at Zetec motors.
