E7loco
    2
Everything posted by E7loco
  1. Wait until you are off your P's and get a 2ZZ-GE... The 99 conquest should have a 1ZZ-FE 1.8l, you will have to check... Lotus use's the 2ZZ-GE engines in the Exige... The Corolla Compressor and Lotus Exige S are SUPERCHARGED! and put out 225 hp (168 kW)(Compressor)-240 hp (179 kW)(Exige S)..... Might be a bit expensive, and over revving can disintegrate the lobe ring in the oil pump causing engine fatality due to oil starvation.... :hmm: The 2ZZ-GE has VVTL-i (valve"lift") so maybe yours has it too (1ZZ-FE)? I don't know much about the "new" breed of Rollas... so you better do your home work... :D Hope this helps.... Ahhhhhh! I just realized you have 'A'E112 in the title..... So you might have a 7A-FE 1.8l in you're Conquest, or some 'A' donk.... If so get a 4A-GZE......... I kinda like the 7A's but 4A-GZE's are the shiz... You'll still have to wait till you're off those P's :dance:
