dog179
    11
Everything posted by dog179
  1. hope so after all this stress i still havent drivin it yet i brought it not going. :) :D
  2. well i had some luck today as i had the day off today as it was laber day up here today so i spent a bit more time running over things in the light for a change.lol.any way checking every thing again with the multimetre can't seem to see any thing wrong till i get to the dizzy then theres nothing ok pop the cap and roter of to check the stater to pick up gap out and i just happened to see a whole heap of bare wire tangled around the dizzy shaft so the sensors are stuffed in the dizzy.so ive ordered anouther 1 but its coming from down south.so hopefully i have it in the next couple of days and then i can let you all know if its fixed at long last.....but in the mean time thank you every 1 that has helped with there advice.
  3. powers up at ciol and igniter but not dissy i have had the same problem since i started doesnt mater what i try?
  4. according to the self dieognostics box the igf isnt picking up a signal.so what would your recomendations be.[thecircuit opening relay.?]
  5. no i actaully went back to the basics of how i used to try and dieognosed older cars .then started checking evry thing with a multimetre.oh one more thing yes i do have injecter pulse.
  6. thanks guys for the responses been busy with work this week then coming home late every night and working on this damn car trying to get it to start and to no avail still no go.now i have replaced the ignighter,plugs,dizzy cap,roter,spark plug leads and i still don't have spark.power suply to ecu is 12.92 volts and ignition signal at ecu is 0.68 which is a little low but it should still start .what am i over looking.??????
  7. ok will check this tomorrow sorry to be a pain but was told ecu was behind left hand kick panel but i pulled the kick panel off this afternoon and could not see it.
  8. i don't want to seem like a numb nut but I'm not used to working on late model gear whats the best way to check for this
  9. how do i check and repair this ?
  10. ok ill start with a bit of history, its a ae 92 seca sx 4age .its got fuel power at coil but no power at dissy no spark at plugs .after any idea,s on what could be wrong .thanks in advance.rick
