rhys2229
    33
Everything posted by rhys2229
  1. nah i ment a aftermarket parts store like ajps in south australia
  2. I ended up getting the arms for $50 off someone else, I put the struts in yesterday, alot better ride now :D
  3. yeh i can get a pair of 86 steering arms with outer tierods and ballpoints for $100, does that price sound normal? i would of thought a bit expensive
  4. Hi i've got a pair of ae86 complete struts to go in my ke70, the guy that sold them to me told me i needed ae86 knuckles to use them in a ke70, but someone else told me that ae86 knuckles are the same as ke70 ones, can anyone help me identify what parts (if any) i need ;) thanks
  5. ended up buying this (the rebuilt one with adapter plate) http://www.rollaclub.com/board/index.php?s...397#entry403345, 32/36 webber from an escort. hope its easy to put on :D
  6. and how did you wire up the two pumps? from the battery with a fuse?
  7. where did you buy your surge tank? ebay have alot but most are probably too big as they hold 2 litres. do parts shops stock them?
  8. is the tank in an ae71 different from a ke70 because my mate has just a vl external pump and it seems to run ok without a surge tank and lift pump,
  9. hey i'm in the process of gathering parts for a 4k to 4age conversion, i need some info on the fuel pump and lines, i'm thinking of using a vl turbo bosch style electric pump (probably cheapo copy), do i need to use a lift pump in the tank as well? or can i just run the electric fuel pump straight from the tank (after a fuel filter)? and where do i get the metal fuel lines from the tank to the engine bay? thanks
  10. would this twin SU carby set up from a 2 litre L20B Datsun work on my 4k? apparently the inlet diameter is 35mm and outlet diamter is 37mm, http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E:X:RTQ:AU:1123 any info would be appreciated cheers
  11. is a 5k engine from a liteace/townace just a 4k with 200cc more displacement? i'm considering swapping to a 5k but thought it might be easier to get the 4k bored out to 1.5 or 1.6. anyone had this done? how much do you reckon it would cost?
  12. Hi i'm new to corollas and i know you can use falcon springs in the rear of a KE70 corolla but can you use them in the front as well? And do they sell shortened shocks for ke70's?
