clayton racing
    4
Everything posted by clayton racing
  1. Plus you will have endless engine cooling problems if you take it out too far, i wouldn't go out any further than you need.
  2. i have done this conversion and had to enlarge the bolt holes in the ke55 steering link rods so the xt130 strut bolt holes would line up. i was going to try and fit the xt130 steering link rods to the ke55 suspension arm ball joint but i never got around to it. also you will need to choose which strut tops as the ke55 strut tops wont fit the xt130 shock absorber rod. either you have to mod the ke55 strut tops to fit or to fit the xt130 strut tops into the ke55, you will need to enlarge the center mounting hole a little and drill new bolting holes. i found this easier. let me know what you find out regarding the coilover conversion as i want to do the same thing? good luck
  3. It seems that there are good arguments, both for and against. The age of the Gemini's is against them and any Corolla Series would be vunerable to the same fate. To over develope them with massive conversions with late model engines and drivetrains would indeed be the death of such a series before it began. I know and agree that many a grand plan to create new catergories has failed because of over complicated rules, mods and budgets. Which is why the concept of the Gemini's worked for so long. They became a sub class of an existing catergory, they stayed as close to the factory car as posible only making small, simple and cheap mods to enhance the cars basic performance. Which is what any Corolla class would need to do if it were to begin and survive at all. So for those out there who would like to continue with this experiment i would like to propose this. A RWD 'K' class and a FWD 'A' class to run and compete together. The 'K' class to be any RWD KE?? Shell with a 5K engine and K50 gearbox. To boost the engine, a racing spec control Cam shaft, Extractors and exhaust to suit, bigger carby jets, a decent airpod to replace the original housing and a thermo fan for the radiator to reduce engine load. But the rest of the running gear to remain at factory specs. The 'A' class to be any FWD AE?? Shell with the 4A-C SOHC engine and it's factory 5 speed manual gearbox. To stay in touch with the KE?? RWD's the Cam shaft would stay at factory specs, carby jets can be changed and an improved air filter element to fit the factory housing. But the rest of the running gear to remain at factory specs. Both classes would run in the CAMS 3J - improved production catergory requiring both classes to conform to those regulations. With a minimum weight of 950kg's for both classes. Both Classes to run a factory sized 14" rim with the same control tyre. Brakes and material to be free as long a you can fit it in the 14" rim. Suspension type and mountings to stay as per factory but spring heights and rates are free (i am trying to develop an adjustable coil over kit for McPherson struts that could be fitted to all standard struts). shock absorbers to be as per factory layout and mountings but must be of a control brand and spec (eg. Monroe GT or similar). The Bodies, outside and in, to remain standard with only the allowed removals and changes as per the 'Improved Productions Regulations'. The benifit in staying as close to factory spec as possible is so what ever your budget is, you can race competitively without racing the size of someone elses wallet, overall its affodable to more willing competitors reducing the need of sponsors and the racing is closer. Sticking to a narrow format also supports the Classes as a whole. if you have open slather rules you may as well not have them and there are plenty of existing catergories already that allow a much broader spectrum of mods and budgets. So for the Rolla fans out there who would like to continue this discussion with a view to a competative budget friendly format of door to door Corolla racing, please share your thoughts?
  4. EXPRESSIONS OF INTEREST Hi all, i just wanted to ask all the Rolla fans out there in Southern Queensland for any expressions of interest in a Corolla Racing Series. The Racing Series i am proposing is a Corolla series designed to be a rival to the Gemini Racing Series with a view to race with them in a two make competition. I am considering some basic parameters of Corolla eligibility, engine and gearbox combination and minimum/maximum modifications. Like the Gemini series I want this Corolla Series to be affordable by keeping the cars to a strict set of design rules. I am basing shell eligibility on Australian RWD Corolla's only excluding the AE86 (sorry its too modern, expensive and doesn't match the Gemini Series criterior) I am looking for feedback on which 4 cylinder engine and 5 speed gearbox combination are easy to get, cheap to buy and simple to fit? I'm leaning towards the 4A engine with the T50 gearbox but i'm not sure on how common and affordable the T50 RWD gearbox is? Any feed back would be appreciated? Happy Cruisin'
