Hey guys thanks for the feedback!! Appreciate it..
SPEC LIST!!
ENGINE..
Seeing that the motor is getting a rebuild starting in a few weeks I'm going to list down the specs of the motor when its finished after the build... It will kinda read out something like this..
4AGE 16V SMALLPORT REDTOP..
-Scat conrods
-JE low comp Forged Pistons
-Cometic metal head gasket
-ARP Head studs, Main studs
-Camtech 292 Duration camshafts
-Fidanza cam gears
-Garrett GT28R 0.64 AR
-38mm external wastegate with screamer pipe
-Sard 650cc injectors
-Walbro internal fuel pump
-Bosch 044 external fuel pump
-Custom surge tank
-Setrab 19 row oil cooler
-Malpassi Fuel reg
-Custon inlet manifold
-Microtech LT10'S
-Microtech X4 coil module
-Greddy oil catch can
DRIVELINE..
-E58 gearbox with L.S.D
-PPG 1st-5th staright cut dog set
-Exedy heavy duty clutch with machined flywheel
Theres a few other things i know I'm missing out on but thats a rough list of what will be getting put in over a few months!!
Power aim when everything has been done and properly tuned will be around 220-240KW on 19-20 psi..
Cheers Lee..
