ca18rolla
    324
Everything posted by ca18rolla
  1. If supplied ready to go then he has no problems then i was just suggest the older outer to save shortening it. I used the case and a detriot lsd and new gears for strength as well
  2. search some off my topics on what i ve done to mine for some infomation
  3. What model hilux diff. You really wanna be using something from a rn10-rn13, otherwise you ll have to have it shortned. If you do get one a suggest Aussie diffs at currimbin for have the spring platforms etc welded on and get them to do disc brake conversion while its there. By the way you can buy mine if you want all the work is done. Owes me over 30k message me for a price
  4. how much are you planning on spending to do ur conversion. I would work out a plan of attack of what you are going to do and what power you are after before you start otherwise you will end up doing things more then once. I have a Ke35 coupe with a ca18det running a gt25/40 (gt28/76r) making 320rwhp, hilux diff, Pbr 290mm brakes, if you wanna know anything message. I m in brisbane
  5. I would be buying a new yoke and uni's from a tail shaft shop. My car broke the standard Ca18det yoke so i had to upgrade to a after market type one which meant a nother new tailshaft. Depending on what power you are chasing i would be talking to the shop and seeing what your options are. I know my 2nd one will handle 450hp+ which is good piece of mind as the 1st one let go at 300hp
  6. Hey mate i used a patrol master as the easy to get hold off and was a easy fit
  7. And you admit to this
  8. maybe 11k if your lucky
  9. i m in qld pod filter is fine exposed just needs to be secure and not flapping around for the transport boys. I use a patrol master with a adaptor bracket. It is a 1' master.
  10. what a mad prick the power skid of it at gazzanats is sweet
  11. That gunky stuff is a sika sealant it alwas stays soft i think they use kero from memory to remove it champ
  12. I use a standard Ke35 one with a three row core installed and thermo switch in the bottom tank for my fan. Also had the outlets changed. Never been hot at all cost $350 at the radiator shop
  13. I hate the chrome trim i brought a plain black rubber locking strip that pushes in think it was like $3 a metre. Looks better i believe. I got my rubbers from rare spares. Took a little bit of working as the front rubber wasn t 100% perfect
  14. I have the hopper stopper twin piston kit on my car the only problem i found is that the front shocks and springs need t be changed to suit the extra unsprung weight. They do work pretty good not quite as i expect but i think the length of the push rod(? the part that push on the piston of the master cyl) needs to made longer.
  15. I am trying to make power cruise just gotta sort some rims and i m there after a quick tune. Nice work on getting down to 12.07
  16. Also did the hopper stopper conversion with 295mm rotors and twin piston PBR sports cailpers. Pretty good setup very happy though they are heavy and add extra unsprung weight. a ford nine inch would be overkill and you wouldn t fit it without cutting the floor up. Go hilux if you want something strong. I would avoid the b/warner as the LSD'S are shit for them. Search some off the topics i have written as i have been over alot of the stuff you are askin many times before. U could always buy my rolla and save yourself 20k everything has been replaced in it from bumper to bumper
  17. you will need to allign the clutch. You really need someone to show u so u understand what it means. You can hire a clutch alligner or use a old input shaft and can hire torque wrenches as well. The white tape idea works really well i would do this for sure. Just wondering why you don't just drive the new car with the old motor though?
  18. runs pretty rich to start with but nice power either way. must be your turbo (maybe) but pretty steep power curve. Make for some fun third geareys
  19. $12k ? someone want this or what
  20. I may make the Bcruising drag day see how the funds are
  21. Wanted 14k but probably could work something out a bit less as i want tyhe cash to build a deck at home give us a call I m in Capalaba. SO you can always come have a look and and think about it
  22. Save yourself the trouble and some money and buy my Ke35 coupe everything is new hilux detriot lsd 300mm brakes 300rwhp forged motor etc
  23. FOr sale again $12.5k Neg want to build a deck or buy a ski so it has to go
  24. I would be suprised if you can find a qld engineer to blue plate this i would find at least two people that will before and before you start and have some serious decussions with both first, The reason for two is incase one closes up shop leaving you high and dry
