deki
Everything posted by deki
  1. i was looking for this information for 4 hours "sigh" finally found it, so for anyone that needs it, here you go :P Engine specifications are the same from 1984 to 1987 for there respective engines. Model: 4A-C Type: 4 cylinder in-line, SOHC Displacement: 96.8 cu. in. (1587 cc) Bore and Stroke: 3.2 x 3.0 in. (81.0 x 77.0 mm) Compression Ratio: 9.0 : 1 Compression Pressure: STD 163 psi @ 250 RPM, LIMIT 128 psi HP (SAE Net): 70 HP @ 4800 RPM Torque (SAE Net): 85 Ft./lbs @ 2800 RPM Valve Timing: Intake Opens: 18 BTDC Intake Closes 46 ATDC Exhaust Opens: 52 BTDC Exhaust Closes: 12 ATDC Spark Plug Type: /California /Federal Nippondenso /W16EXR-U11 /W16EXR-U11 /W14EXR-U11 NGK /BPR5EA-L11 /BPR5EA-L11 /BPR5EY11 /BPR5EA11 /BPR5EY11 or BPR4EY11 Spark Plug Gap: 0.043 in. (1.1mm) Firing Order: 1-3-4-2 Ignition Timing: 5 BTDC @ Max. 950 RPM (With vacuum advance off) **NOTE** M/T and A/T in "N" range Valve Clearance: Intake (Hot): 0.008 in. (0.20 mm) Exhaust (Hot): 0.012 in. (0.30 mm) Cooling System: Type: Water Cooled Radiator: Vertical flow fin and tube Radiator Cap Pressure: 10.7-14.9 psi (0.75-1.05 kg/sq. cm) Waterpump: Centifugal v-belt drive Thermostat Valve Opening: 190 F (88 C) Capacity: 5.9 qt. (5.6 liter) M/T With Heater: 5.8 qt. (5.5 liter) A/T Fuel System: Type of Carburetor: Downdraft, 2 Barrel Fuel Pump: Mechanical Diaphragm Fuel Pressure: 2.5-3.5 psi (0.18-0.25 kg/ sq. cm) Fuel Filter Type: Paper Filter Element (flow through) Fuel Tank Capacity: 13.2 gal. (50 liter) Fuel Grade: USE UNLEADED FUEL ONLY (Research Octane No. 91 Anti Knock Index 87 or Higher) Lubrication System: Type: Mechanical Oil Pump: Gear Type Oil Filter Capacity: 0.3 qt. Recommended Motor Oil: API grade SF or better Oil Capacity /w Filter: 3.5 qt. (3.3 liter) Electrical System: Battery (volts/ amp hours): 12V/50A - hr Alternator (volts/ amps): 12V/55A Starter Motor (volts/ kW): 12V/1.0 KW M/T - 12V/1.4 KW A/T
