hitoriko
    28
Everything posted by hitoriko
  1. DAMN! why can't you be in melbs :'(
  2. I'm sorry but...... its a corolla why that kind of styling if its to take the piss out of the gemini/vl/falcon crowd - doing it very well and props :P BUT if it isn't i'll keep my opinion to myself
  3. ashleys in sunshine has a ae8x twin cam (i took a short motor) but the head and acc are there - also a couple ke70's
  4. YES! i do go to that shop the roast sangas are great haha - and the young chick that works there is such a cutie :(
  5. Yes its possible you can do it - welcome to rollaclub - but pleae in future use the search fuction as this has been covered countless times before
  6. actually the ae86 ADM 4ac engines have 6 bolt flywheels soremoving the carb engine and droping in a 4af/age hybrid would bolt in prefectly leaving you with all the std gear but then again why bother
  7. I work for VW in camberwell and formerly of peugeot in CBD if anyone needs parts for Ford, Nissan, Toyota, VW or Peugeot let me know and i'll look after you best i can on price IF you need parts i'll need the VIN number also just name what you need and a VIN and if i can't find a genuine item i'll get a good quality Non Gen item
  8. good one on mcintyre rd in sunshine
  9. whats the std compression and what would the compression be if the head had been decked 20thu - and all other things remained standard
  10. thanks guys but i don't like that white dial look imo it looks cheap and nasty at least if i can find a ke30 dash i can make it different if you hvae custom dials/dash/gauges pics would be great
  11. thanks mate that helps alot
  12. yeah saw those gauges but want something different
  13. i didnt mean to under value it i was giving ne opinion - on info given
  14. well i was thinking about something like out of a 260z i like the old school gauge dashs hence that ask :y:
  15. dang....
  16. depends.... pics will help but generally you'd beable to get more wrecking her to specialist peoples (us!) then selling whole as without rwc etc.. and not in good conditionetc.. you wont get more then 300 -500 in saying that depends on the buyer so up to you really
  17. anyone?
  18. ok i have this cam in my possesion now and double valve springs so will this setup work? Twin Sidedraft SU carbs Port Polished head, 3 angle grind, decked 20 thou Stock bottom end Extractors Electric dizzy Lightened flywheel HD Clutch Std 5speed Box Std 5speed Diff Running stockies most of the time but also using 13x7" superlights Also i'll be running on 98RON BP fuel i think it should be fine to run that cam but am i missing anything or will it all now just come down to the tune?
  19. I'm looking at changing the dash in my ke70 I'm wanting more of an old school look like what the ke30/35/55 had with the round gauges in there seperate pods does anyone know if any of them fit or has anyone done it? if so some pics of whats been done etc.. cheers
  20. no i mean like a cold air intake i saw some vid i think it was on the front page of ae86dc where they had a metal box?
  21. i've borught that cam off him
  22. anyone done anything for sidedrafts?
  23. more ribs the stronger it is
  24. hey gys so i don't make the same mistakes this is the setup i'll be running: Twin Sidedraft SU carbs Port Polished head, 3 angle grind, decked 20 thou Stock bottom end Extractors Electric dizzy Lightened flywheel HD Clutch Std 5speed Box Std 5speed Diff Running stockies most of the time but also using 13x7" superlights Also i'll be running on 98RON BP fuel now I'm not sure but is there anything that i should change before i put it back together ie. should i get ACL pistons and rings (as there mentioned in the FAQ and i work in the trade - spareparts - so i should get them cheap) i think this will be suitable to run and run quite well! :|
